Has anyone had any luck decrypting Blue Planet II? It might be available according to this:
https://docs.google.com/spreadsheets/d/ ... edit#gid=0
It's listed with an "X" in the MakeMKV column, but doesn't have a key listed.
I'm also getting read errors on Disc 1, but Discs 2 and 3 were able to backup fine, just not decrypt -- saying the volume key is unknown.
Blue Planet II
preserve
Re: Blue Planet II
In that case you'll probably want to replace your set (super easy if you buy from Amazon) in order to get a good disc 1.
If you are using the latest MakeMKV and the latest hashed keys file, and the hashed keys file is correctly placed in your MakeMKV data directory, then you should submit the AACS dumps created by MakeMKV to svq@makemkv.com, and then the discs will be supported usually within a few days in the next hashed keys update.
FAQ: http://makemkv.com/forum2/viewtopic.php?f=12&t=16883
Using: ASUS BW-16D1HT 3.00
