Odd Playback Issue
dasquared
Odd Playback Issue
Post by dasquared »
Apologies if this is redundant, but I did try searching the forums for related issues...
I began backing up my movies onto a server for in home streaming. The vast majority have been fine. A few (right now, limited to Interstellar BR and Atomic Blonde BR) have had no issues in anything except playback - no listed errors at all, nothing skipped, etc during the conversion). The exact message I get is "Can't play because the item's file format isn't supported." All of the file info is the same type, etc as every other file (MKV), but something simply won't allow playback. Thoughts?
*fingers crossed it's something easy but not too stupid on my part*
Re: Odd Playback Issue
Does your player support h.265 video?
dasquared
Post by dasquared »
It SAYS it does, but I am using VLC Player (3.0.1) for what it's worth. Of course, this is also just the PC for the drive I want to use as a media player, just find it odd that I can't seem to play only a few titles. Since my post, I ran Deadpool. Main movie was fine, but some of the extra content was also unreadable...will see if my devices in the house can play them back before deleting. And I have rerun Interstellar and Atomic Blonde each twice with same results...
Is it ALL MKV files, or just ones with UHD video in them?
Searching for the exact error message netted a variety of pages that MIGHT help. If it's all MKV files, it may be a registry entry that is screwed up. But, if it's just a few, it points to a codec issue.
As far as I can tell, the exact text is a Windows movie app message, not VLC.
dasquared
Post by dasquared »
There are NO error messages throughout the processing of the BR, and it is only some of them, or even only some features/files that come from the same disc (on Deadpool, for instance, only the main movie worked, while deleted scenes, interviews, etc were not playable). And none of my discs are 4K, but only some of the BR have the issue, no DVDs have had it (yet)...
dasquared
Post by dasquared »
Well, for now I uninstalled, restarted, and reinstalled VLC and now they all seem to play fine, so it must have been an issue there. Thank you for trying to work with me!
