Dunkirk with ASUS BW-16D1HT
bernard
Post by bernard » Fri Mar 16, 2018 7:20 pm
What am I doing wrong?
MakeMKV v1.12.0 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Bernard/MakeMKV_log.txt
Saved SD dump file as C:\Users\Bernard/.MakeMKV/dump_SD_9E91B21F784F515B7809.tgz
Saved AACS dump file as C:\Users\Bernard/.MakeMKV/MKB20_v61_Dunkirk_AAF7.tgz
DEBUG: Code 0 at mV4(%n/4s|39{CnS:121264257
DEBUG: Code 0 at mV4(%n/4s|39{CnS:121265890
Re: Dunkirk with ASUS BW-16D1HT
Post by Woodstock » Fri Mar 16, 2018 10:52 pm
Assuming that you have the latest key file in your MakeMKV directory, the key for your particular disk may not be known yet.
In that case, you would send the file C:\Users\Bernard/.MakeMKV/dump_SD_9E91B21F784F515B7809.tgz to svq@makemkv.com for analysis and inclusion in the next update of the key file.
bernard
Post by bernard » Sat Mar 17, 2018 6:02 pm
Woodstock, is there a separate key file? Or is it baked into the executable? I'm not seeing such a separate file.
I did send the dumps.
st4evr
Post by st4evr » Sat Mar 17, 2018 6:38 pm
Please read Mike’s instructions in this sticky:
http://www.makemkv.com/forum2/viewtopic ... 12&t=16959
bernard
Post by bernard » Sat Mar 17, 2018 7:55 pm
Success!! Thank you Woodstock and st4evr!
