Top Gear Season 19 Disc 2 error
Titancom
#1 Post by Titancom » Sun Mar 11, 2018 12:07 am
Hi Team,
I have gone through a lot of disc's converting from DVD\BD to MKV format and just hit that error message: It appears that you are opening the disc processed by DVDFab/MacTheRipper which is known to produce damaged VOB files. Errors may follow - please use original disc instead.
Not sure why that is now coming up after converting the first 18 season and now get stuck on season 19 second disc?
error in log file:Using direct disc access mode
003342:0204 It appears that you are opening the disc processed by DvdFab/MacTheRipper which is known to produce damaged VOB files. Errors may follow - please use original disc instead.
Title skip vts=1 pgcn=1 hash=2DC21E01B94BF2E9
Title skip vts=1 pgcn=3 hash=CE7E295C88055DD6
003025:0000 Title #3 has length of 12 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Application exited at Sat Mar 10 23:58:26 2018
Any help appreciated thanks.
See attached file.
