Buying license
jpsdr
Buying license
#1 Post by jpsdr » Sat Mar 10, 2018 6:53 pm
Hello.
I'm thinking about buying a license, but the PC it will be used on is totaly offline, and will never be connected to internet.
Is it an issue for license activation ?
Re: Buying license
#2 Post by Woodstock » Sat Mar 10, 2018 8:32 pm
No. You plug the license in using Help->Register, then the program knows it is registered.
Not connected to internet means that it won't be able to check for updated versions or receive SVQ files, so there may be some content you can't rip properly until those things are updated (you'll be told when you try ripping), but being off-line is not a hindrance otherwise.
Sannom
Re: Buying license
#3 Post by Sannom » Fri Apr 20, 2018 6:02 pm
EDIT : nevermind, I found out what my mistake was. Sorry for the misunderstanding!
