Buying license
jpsdr
Buying license
Post by jpsdr »
Hello.
I'm thinking about buying a license, but the PC it will be used on is totaly offline, and will never be connected to internet.
Is it an issue for license activation ?
Re: Buying license
No. You plug the license in using Help->Register, then the program knows it is registered.
Not connected to internet means that it won't be able to check for updated versions or receive SVQ files, so there may be some content you can't rip properly until those things are updated (you'll be told when you try ripping), but being off-line is not a hindrance otherwise.
Sannom
Re: Buying license
Post by Sannom »
EDIT : nevermind, I found out what my mistake was. Sorry for the misunderstanding!
