UHD - Thor: Ragnarok - Correct Playlist
jayper
Post by jayper »
Thor: Ragnarok
4K UHD Disc
Decrypts properly, but I am seeing two playlists of equal length, same language/sub tracks but different segment maps. Does anyone have any insight?
Re: UHD - Thor: Ragnarok - Correct Playlist
Not sure about your region/version, however, I have the Australian version and there are 3 playlists for 02:10:31. These are:
00004.mpls
00800.mpls
00801.mpls
I've found that 2 of the playlists (00004 & 00800) play the same files/order so either one of these is correct.
jayper
Post by jayper »
Thanks! Great question, I failed to add. This is for the US Best Buy Steelbook version.
I have:
Name: MARVEL'S THOR: RAGNAROK
Source file name: 00800.mpls
Duration: 2:10:30
Chapters count: 18
Segment count: 5
Segment map: 800,801,802,803,804
File name: MARVEL'S_THOR_RAGNAROK_t00.mkv
Source file name: 00801.mpls
Duration: 2:10:30
Chapters count: 18
Segment count: 5
Segment map: 800,805,802,806,804
File name: MARVEL'S_THOR_RAGNAROK_t01.mkv
00800.mpls should be the correct playlist. If you look at the playlist in MediaInfo, it should show the video files in the following playback order:
00800.m2ts
00801.m2ts
00802.m2ts
00803.m2ts
00804.m2ts
angelgraves13
Post by angelgraves13 »
For Disney titles, 800 is always the correct one for English.
cherishjoo
Post by cherishjoo »
How do you confirm the correct playlist? I mean before ripping?
Best Bluray DVD Ripping Solution
If it is released by Disney and you want English, check out the "800" play list first.
If it's released by Lionsgate or a related studio, make sure you have Java installed and hope MakeMKV can find it, otherwise do a forum search for the title of the movie to see if someone else found it.
Stoke192
Post by Stoke192 »
Anyone managed to backup the UK steelbook version ?, I can read the disk but i'm unable to back it up.
I've emailed the ACCS dump over to the provided email, Although Thor is listed in the Hashed keys and KeyDB files, It's a different version ?
Manufacturer: ASUS
Product: BW-16D1HT
Revision: 3.01
Serial number: SIK9PH6KD254
Firmware date: 2117-03-31 14:26:
Bus encryption flags: 1F
Highest AACS version: 62
Disc Information
Label: THOR_RAGNAROK
Timestamp: 2018-01-02 18:33:10
Data capacity: 61.46 Gb
Disc type: BD-ROM UHD
Number of layers: 2
Bus encryption flags: 80
Edit: Never mind, sorted now......Maybe I need to read the instructions of where to put the Hashed keys file correctly :roll:
andcbii
Post by andcbii »
MartyMcNuts wrote:00800.mpls should be the correct playlist. If you look at the playlist in MediaInfo, it should show the video files in the following playback order:
00800.m2ts
00801.m2ts
00802.m2ts
00803.m2ts
00804.m2ts
How do you do this?
You need to have MediaInfo installed on your PC. If you have the K-Lite codec pack installed you should have MediaInfo. Otherwise, you can download a MediaInfo installer. I just google'd MediaInfo and it was the first link.
Once you have it installed, just right click on a playlist or video file and select MediaInfo from the menu.
Norman
Post by Norman »
jayper wrote:Thor: Ragnarok
4K UHD Disc
It doesn't for me. Where do you get keys?
beatsntoons
Post by beatsntoons »
what happens if you select the wrong playlist? I've always just picked a random one!
Deraga
Post by Deraga »
beatsntoons wrote:what happens if you select the wrong playlist? I've always just picked a random one!
The movie can skip around to different scenes or the words can be in a different language. stuff like that.
It could also blow up your computer. :lol: :D
jonghotti
Post by jonghotti »
What do you guys do for audio for this? Suppose I want just the atmos track since I copy the mkv files to a usb stick and play them through my x800 player or st5000 sound bar (both Sony products). I've not yet learned how to name the audio tracks, not sure if it can be done just using the mkv file as playback, but want to verify i've got the atmos ripped.
Any suggestions?
Thank you!
