I can get the second disc to work and copy but when I try to use the first disc this is what comes up.....
Debug logging enabled, log will be saved as C:\Users\Spock/MakeMKV_log.txt
Title #00053.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00404.mpls was added as title #0
File 00401.mpls was added as title #1
File 00201.mpls was added as title #2
File 00101.mpls was added as title #3
File 00100.mpls was added as title #4
File 00055.mpls was added as title #5
Title #00054.mpls has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00005.m2ts has length of 103 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00013.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00012.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00069.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00052.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00051.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00050.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00049.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00048.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00047.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00046.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00045.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00044.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00043.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00042.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00041.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00039.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00038.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00037.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00035.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00034.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00022.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00021.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00026.m2ts was added as title #6
File 00075.m2ts was added as title #7
Title #00024.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00073.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00004.m2ts has length of 17 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00003.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00002.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00074.m2ts was added as title #8
File 00077.m2ts was added as title #9
File 00076.m2ts was added as title #10
Title #00011.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 7 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00007.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00009.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00006.m2ts has length of 5 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title 00401.mpls is equal to title 00201.mpls and was skipped
Saving 2 titles into directory C:/Video/Ben_Hur_50th_Anniversary_UCE
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00072.m2ts' at offset '13227257856'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '13227257856'
DEBUG: Code 3221225628 at ipIew^gGnGByEUZg1a:121262969
DEBUG: Code 100864261 at ipIew^gGnGByEUZg1a:121262969
DEBUG: Code 0 at :TZBv"<vmt/\_M%9YF-S:29395034
DEBUG: Code 0 at k`Gfy'w(Cq4$)}}QB'PA:29394045
DEBUG: Code 0 at :TZBv"<vmt/\_M%9YF-S:121262647
DEBUG: Code 6458622 at :TZBv"<vmt/\_M%9YF-S:213129593
DEBUG: Code 0 at js~o!'PoT+fMv%n6[f3G8:29399197
LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
Failed to save title 2 to file C:/Video/Ben_Hur_50th_Anniversary_UCE/Ben_Hur_50th_Anniversary_UCE_t02.mkv
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/BDMV/STREAM/00072.m2ts' at offset '13236695040'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '13236695040'
DEBUG: Code 6463230 at :TZBv"<vmt/\_M%9YF-S:213129593
Failed to save title 3 to file C:/Video/Ben_Hur_50th_Anniversary_UCE/Ben_Hur_50th_Anniversary_UCE_t03.mkv
Encountered 22 errors of type 'Read Error' - see /errors/read/
0 titles saved, 2 failed
BEN HUR 50TH ANNNIVERSARY BLURAY
Re: BEN HUR 50TH ANNNIVERSARY BLURAY
There is a portion of the disk that your drive cannot read. Most likely, this is because of contamination on the surface, and a damp soft cloth is often all that is necessary to correct the situation.
In addition to fingerprints, there is some sort of chemical being used during the packaging of a lot of disk in the last couple of years that seems to migrate from the packaging to the media over time. There's a picture of it in "check here first for errors" topic in this section: http://makemkv.com/forum2/viewtopic.php?f=8&t=15055
