American Gangster (Extended Edition) DVD
Jonathan
Post by Jonathan » Sat Mar 03, 2018 1:34 pm
Hi, ripped many DVDs with no problems but American Gangster (Extended Edition) is refusing to rip, any ides? Log follows:
Debug log started at Sat Mar 03 11:27:32 2018 , written by MakeMKV v1.12.0 win(x64-release)
001005:0000 MakeMKV v1.12.0 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Jonathan/MakeMKV_log.txt
003025:0000 Title #1 has length of 14 seconds which is less than minimum title length of 20 seconds and was therefore skipped
003019:0000 Cells 2-end were skipped due to cell commands (structure protection?)
003028:0000 Title #2 was added (1 cell(s), 0:00:23)
Title skip vts=7 pgcn=1 hash=A38F1309CD19348D
003028:0000 Title #3 was added (1 cell(s), 0:00:23)
003025:0000 Title #3/0/1 has length of 1 seconds which is less than minimum title length of 20 seconds and was therefore skipped
Title skip vts=5 pgcn=1 hash=FA51D6285C09CB60
003028:0000 Title #4 was added (1 cell(s), 0:00:21)
003025:0000 Title #4/0/1 has length of 1 seconds which is less than minimum title length of 20 seconds and was therefore skipped
Title skip vts=5 pgcn=2 hash=01FD6C2D4BF4CF4E
003028:0000 Title #5 was added (1 cell(s), 0:00:44)
003025:0000 Title #5/0/1 has length of 1 seconds which is less than minimum title length of 20 seconds and was therefore skipped
Title skip vts=4 pgcn=1 hash=D602A4F65D505E1E
003028:0000 Title #6 was added (1 cell(s), 0:00:44)
003025:0000 Title #6/0/1 has length of 1 seconds which is less than minimum title length of 20 seconds and was therefore skipped
Title skip vts=3 pgcn=1 hash=B684B16666359FC6
003028:0000 Title #7 was added (1 cell(s), 0:00:49)
003025:0000 Title #7/0/1 has length of 1 seconds which is less than minimum title length of 20 seconds and was therefore skipped
Title skip vts=2 pgcn=1 hash=E5030B5950DEDC3E
003024:1000 Complex multiplex encountered - 16 cells and 3683 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #8 was added (58 cell(s), 2:30:01)
003024:1000 Complex multiplex encountered - 16 cells and 3992 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #9 was added (58 cell(s), 2:48:11)
005014:0000 Saving 3 titles into directory E:/Ripping/American Gangster (Extended Edition) (2007) [18]
001003:0020 DEBUG: Code 3221225628 at >CkE!Ft[yN7X_+#K+RC#nC3t:213130398
001003:0020 DEBUG: Code 3221225628 at %Rk`d99_8 0N|*#C:29393953
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26624'
DEBUG: Code 3221225628 at ipIew^gGnGByEUZg1a:213130904
001003:0020 DEBUG: Code 3221225628 at ipIew^gGnGByEUZg1a:121262969
001003:0020 DEBUG: Code 100864261 at RxbsM'lzAHfTA`<4:121269823
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '26624'
DEBUG: Code 100864261 at ipIew^gGnGByEUZg1a:213130904
001003:0020 DEBUG: Code 100864261 at ipIew^gGnGByEUZg1a:121262969
001003:0020 DEBUG: Code 0 at :TZBv"<vmt/\_M%9YF-S:29395034
001003:0020 DEBUG: Code 0 at KIuw5L[4ohx~lKE\EO]:213129915
001003:0020 DEBUG: Code 0 at :TZBv"<vmt/\_M%9YF-S:121262647
001003:0020 DEBUG: Code 13 at :TZBv"<vmt/\_M%9YF-S:213129593
001003:0020 DEBUG: Code 0 at js~o!'PoT+fMv%n6[f3G8:29399197
001003:0020 DEBUG: Code 0 at +0@9IOhtcvI)QCpq-mB:213132054
004007:0010 AV synchronization issues were found in file 'E:/Ripping/American Gangster (Extended Edition) (2007) [18]/title06.mkv' (title #7)
004008:0010 AV sync issue in stream 1,2 at 0:59:34.568 with duration of 8ms : short audio gap was removed, audio skew is -8ms
004008:0010 AV sync issue in stream 1,2 at 1:02:13.648 with duration of 8ms : short audio gap was removed, audio skew is -16ms
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '491014144'
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '491014144'
001003:0020 DEBUG: Code 239753 at :TZBv"<vmt/\_M%9YF-S:213129593
001002:0020 LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
005003:0000 Failed to save title 6 to file E:/Ripping/American Gangster (Extended Edition) (2007) [18]/title06.mkv
004007:0010 AV synchronization issues were found in file 'E:/Ripping/American Gangster (Extended Edition) (2007) [18]/title07.mkv' (title #8)
004008:0010 AV sync issue in stream 1 at 0:20:35.760 with duration of 16ms : short audio gap was removed, audio skew is -16ms
004008:0010 AV sync issue in stream 1 at 0:52:49.808 with duration of 32ms : audio gap - 1 missing frame(s)
004008:0010 AV sync issue in stream 1 at 1:00:20.712 with duration of 8ms : short audio gap was removed, audio skew is -8ms
004008:0010 AV sync issue in stream 1 at 1:05:10.920 with duration of 32ms : audio gap - 1 missing frame(s)
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '493760512'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '493891584'
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '493891584'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '494153728'
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '494153728'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '494544896'
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '494544896'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '495069184'
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '495069184'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '495591424'
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '495591424'
001003:0020 DEBUG: Code 241988 at :TZBv"<vmt/\_M%9YF-S:213129593
005003:0000 Failed to save title 7 to file E:/Ripping/American Gangster (Extended Edition) (2007) [18]/title07.mkv
002023:0000 Encountered 37 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
error=0x06031105 count=37 name=Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR
Encountered 33 unclassified errors
error=0xC000009C count=33 name=OS error - STATUS_DEVICE_DATA_ERROR
005004:0080 1 titles saved, 2 failed
005037:0204 Copy complete. 1 titles saved, 2 failed.
Ta
Jonathan
MakeMKV_log.txt
(25.7 KiB) Downloaded 832 times
Re: American Gangster (Extended Edition) DVD
Post by Woodstock » Sat Mar 03, 2018 3:04 pm
Your disk has areas the drive cannot read. If the drive can't read them, MakeMKV can't save them.
Have you checked out this message in the Bluray section? http://makemkv.com/forum2/viewtopic.php?f=8&t=15055
Have you tried cleaning the disk?
Jonathan
Post by Jonathan » Sat Mar 03, 2018 4:38 pm
Disc is brand-new, from a shrink-wrap case! No scratches what-so-ever. Have swapped the disk for another one which has ripped OK. Can only assume there was a problem on the other disk.
Jonathan
Post by Woodstock » Sat Mar 03, 2018 6:10 pm
If you believe "new in wrapper" means anything, you need to look at the picture in this post: http://makemkv.com/forum2/viewtopic.php ... 055#p53448
Just because you can't see something doesn't mean it can't affect the laser's ability to read microscopic dots.
And the opposite is true - I have 5 disks that are rather badly scratched, only two of which had read errors. And those read error are actually mastering issues; the raw disk can be read just fine, but there is a navigation error in the recorded bits.
