American Gangster (Extended Edition) DVD
Jonathan
Post by Jonathan »
Hi, ripped many DVDs with no problems but American Gangster (Extended Edition) is refusing to rip, any ides? Log follows:
Debug log started at Sat Mar 03 11:27:32 2018 , written by MakeMKV v1.12.0 win(x64-release)
001005:0000 MakeMKV v1.12.0 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\Jonathan/MakeMKV_log.txt
003025:0000 Title #1 has length of 14 seconds which is less than minimum title length of 20 seconds and was therefore skipped
003019:0000 Cells 2-end were skipped due to cell commands (structure protection?)
003028:0000 Title #2 was added (1 cell(s), 0:00:23)
Title skip vts=7 pgcn=1 hash=A38F1309CD19348D
003028:0000 Title #3 was added (1 cell(s), 0:00:23)
003025:0000 Title #3/0/1 has length of 1 seconds which is less than minimum title length of 20 seconds and was therefore skipped
Title skip vts=5 pgcn=1 hash=FA51D6285C09CB60
003028:0000 Title #4 was added (1 cell(s), 0:00:21)
003025:0000 Title #4/0/1 has length of 1 seconds which is less than minimum title length of 20 seconds and was therefore skipped
Title skip vts=5 pgcn=2 hash=01FD6C2D4BF4CF4E
003028:0000 Title #5 was added (1 cell(s), 0:00:44)
003025:0000 Title #5/0/1 has length of 1 seconds which is less than minimum title length of 20 seconds and was therefore skipped
Title skip vts=4 pgcn=1 hash=D602A4F65D505E1E
003028:0000 Title #6 was added (1 cell(s), 0:00:44)
003025:0000 Title #6/0/1 has length of 1 seconds which is less than minimum title length of 20 seconds and was therefore skipped
Title skip vts=3 pgcn=1 hash=B684B16666359FC6
003028:0000 Title #7 was added (1 cell(s), 0:00:49)
003025:0000 Title #7/0/1 has length of 1 seconds which is less than minimum title length of 20 seconds and was therefore skipped
Title skip vts=2 pgcn=1 hash=E5030B5950DEDC3E
003024:1000 Complex multiplex encountered - 16 cells and 3683 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #8 was added (58 cell(s), 2:30:01)
003024:1000 Complex multiplex encountered - 16 cells and 3992 VOBUs have to be scanned. This may take some time, please be patient - it can't be avoided.
003028:0000 Title #9 was added (58 cell(s), 2:48:11)
005014:0000 Saving 3 titles into directory E:/Ripping/American Gangster (Extended Edition) (2007) [18]
001003:0020 DEBUG: Code 3221225628 at >CkE!Ft[yN7X_+#K+RC#nC3t:213130398
001003:0020 DEBUG: Code 3221225628 at %Rk`d99_8 0N|*#C:29393953
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '26624'
DEBUG: Code 3221225628 at ipIew^gGnGByEUZg1a:213130904
001003:0020 DEBUG: Code 3221225628 at ipIew^gGnGByEUZg1a:121262969
001003:0020 DEBUG: Code 100864261 at RxbsM'lzAHfTA`<4:121269823
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '26624'
DEBUG: Code 100864261 at ipIew^gGnGByEUZg1a:213130904
001003:0020 DEBUG: Code 100864261 at ipIew^gGnGByEUZg1a:121262969
001003:0020 DEBUG: Code 0 at :TZBv"<vmt/\_M%9YF-S:29395034
001003:0020 DEBUG: Code 0 at KIuw5L[4ohx~lKE\EO]:213129915
001003:0020 DEBUG: Code 0 at :TZBv"<vmt/\_M%9YF-S:121262647
001003:0020 DEBUG: Code 13 at :TZBv"<vmt/\_M%9YF-S:213129593
001003:0020 DEBUG: Code 0 at js~o!'PoT+fMv%n6[f3G8:29399197
001003:0020 DEBUG: Code 0 at +0@9IOhtcvI)QCpq-mB:213132054
004007:0010 AV synchronization issues were found in file 'E:/Ripping/American Gangster (Extended Edition) (2007) [18]/title06.mkv' (title #7)
004008:0010 AV sync issue in stream 1,2 at 0:59:34.568 with duration of 8ms : short audio gap was removed, audio skew is -8ms
004008:0010 AV sync issue in stream 1,2 at 1:02:13.648 with duration of 8ms : short audio gap was removed, audio skew is -16ms
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '491014144'
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '491014144'
001003:0020 DEBUG: Code 239753 at :TZBv"<vmt/\_M%9YF-S:213129593
001002:0020 LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
005003:0000 Failed to save title 6 to file E:/Ripping/American Gangster (Extended Edition) (2007) [18]/title06.mkv
004007:0010 AV synchronization issues were found in file 'E:/Ripping/American Gangster (Extended Edition) (2007) [18]/title07.mkv' (title #8)
004008:0010 AV sync issue in stream 1 at 0:20:35.760 with duration of 16ms : short audio gap was removed, audio skew is -16ms
004008:0010 AV sync issue in stream 1 at 0:52:49.808 with duration of 32ms : audio gap - 1 missing frame(s)
004008:0010 AV sync issue in stream 1 at 1:00:20.712 with duration of 8ms : short audio gap was removed, audio skew is -8ms
004008:0010 AV sync issue in stream 1 at 1:05:10.920 with duration of 32ms : audio gap - 1 missing frame(s)
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '493760512'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '493891584'
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '493891584'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '494153728'
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '494153728'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '494544896'
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '494544896'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '495069184'
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '495069184'
002003:0000 Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '495591424'
002003:0000 Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '495591424'
001003:0020 DEBUG: Code 241988 at :TZBv"<vmt/\_M%9YF-S:213129593
005003:0000 Failed to save title 7 to file E:/Ripping/American Gangster (Extended Edition) (2007) [18]/title07.mkv
002023:0000 Encountered 37 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
error=0x06031105 count=37 name=Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR
Encountered 33 unclassified errors
error=0xC000009C count=33 name=OS error - STATUS_DEVICE_DATA_ERROR
005004:0080 1 titles saved, 2 failed
005037:0204 Copy complete. 1 titles saved, 2 failed.
Ta
Jonathan
MakeMKV_log.txt
(25.7 KiB) Downloaded 799 times
Re: American Gangster (Extended Edition) DVD
Your disk has areas the drive cannot read. If the drive can't read them, MakeMKV can't save them.
Have you checked out this message in the Bluray section? http://makemkv.com/forum2/viewtopic.php?f=8&t=15055
Have you tried cleaning the disk?
Jonathan
Post by Jonathan »
Disc is brand-new, from a shrink-wrap case! No scratches what-so-ever. Have swapped the disk for another one which has ripped OK. Can only assume there was a problem on the other disk.
Jonathan
If you believe "new in wrapper" means anything, you need to look at the picture in this post: http://makemkv.com/forum2/viewtopic.php ... 055#p53448
Just because you can't see something doesn't mean it can't affect the laser's ability to read microscopic dots.
And the opposite is true - I have 5 disks that are rather badly scratched, only two of which had read errors. And those read error are actually mastering issues; the raw disk can be read just fine, but there is a navigation error in the recorded bits.
