I am in the same situation and I ended up going with the Asus BW-16D1HT with a Vantec external enclosure. Works like a champ.aprosak wrote:kingston12 wrote:
Is this currently the only UHD friendly external drive available? I'm running a laptop with no ability to expand it and buying a desktop is not an option.
UHD drives
Re: UHD drives
Re: UHD drives
Hi guys,
if I understand you right, my device would not work, because of the wrong service code. Is there any possibility to get this to work?
If not, I would buy an ASUS BW-16D1HT.
Regards Hoppel
OS device name: F:
Product: BD-RE BH16NS40
Revision: 1.03
Serial number: K96F7UF5237
Firmware date: 2115-05-26 17:14:
Highest AACS version: 62Regards Hoppel
- bh16ns40.PNG (151.39 KiB) Viewed 43542 times
TeddyRaspin
Re: UHD drives
NS40 is not UHD friendly, I'm very sorry.
BUFFALO external slim UHD drives
after buying a BRXL-PT6U2VB (manufactured November 2017), I was rather disappointed that the original FW BN10 (Date: 2017-05-30) was incapable of reading UHD blu-rays. Flashing to the latest FW BN11 (Date: 2017-11-20) did not improve a thing. Since the old FW v1.02 ought to be the same for numerous BUFFALO slim drives:
is there any way to force flash this FW Version?
BRUHD-PU3
BRXL-PT6U3
BRXL-PT6U2V
DVSM-PTS58U2
DVSM-PT58U2VRe: UHD drives
Just got a WH14NS40 and I've been able to Rip Deadpool no problem.jmonier wrote:WH14NS40 works fine for me. The Asus firmware can be loaded into it same as the WH16NS40.
However I was not able to rip Oblivion... The disc won't even open.
I tried to load the Asus 3.02 firmware that I got from Asus website called ASUS ODD FW Updater for BW-16D1HT.exe
But each time I press Start I get a popup saying: There is no target drive.
Am I missing something?
Thanks in advance, people
TeddyRaspin
Re: UHD drives
Because no Asus drive is detected. You have to use the LG crossflash flasher and load the clean firmware.ArieS wrote: I tried to load the Asus 3.02 firmware that I got from Asus website called ASUS ODD FW Updater for BW-16D1HT.exe
I've written a specific guide to do that. https://www.makemkv.com/forum2/viewtopi ... 16&t=17058
Re: UHD drives
Wow, thanks Teddy for the great guide but it's really 'chinese' to me... This looks way too complicated for me.TeddyRaspin wrote:Because no Asus drive is detected. You have to use the LG crossflash flasher and load the clean firmware.ArieS wrote: I tried to load the Asus 3.02 firmware that I got from Asus website called ASUS ODD FW Updater for BW-16D1HT.exe
I was hoping for an .exe and be done with it
TeddyRaspin
Re: UHD drives
Try this. Run the exe and select the firmware bin file (ASUS 3.02).
- Flasher.zip
- (2.96 MiB) Downloaded 1518 times
Re: UHD drives
Thank you Teddy!
The update went smoothly. Very appreciated and thank you for taking the time!
Even though it still cannot read Oblivion
at least I have the last firmware which I've read helps my drive with speed...
TeddyRaspin
Re: UHD drives
@ArieS
Maybe your Oblivion UHD disc is a faulty one.
HerpoTheFoul
Re: UHD drives
I got a LG BH16NS55 manufactured in March 2017, ROM is 1.02 and SVC is NS55
I can't try it right now as I don't have the enclosure yet, but does it read them?
EDIT: Yes it does:
EDIT: Yes it does:
All BH16NS55 are SVC NS55
the WH16NS40 & BH16NS40 must have SVC NS50 to be UHD friendly. The NS40 drives have been around for years and were originally SVC NS40. The later one's from around the end of 2015 or early 2016, I believe are SVC NS50. All BH16NS55 are SVC NS55.
So, whenever someone is talking about having SVC NS50, they are referring to the WH16NS40 & BH16NS40 drives.
Re: UHD drives
i'm in the market for a new drive.
does the ASUS BW-16D1HT defiantly work copying 4k discs?
thanks
thanks
Re: UHD drives
Yes if you have a 3.00, 3.01 or 3.02 firmware. Firmware 3.03 fix the loophole, and if you have an old disc with FW 1.xx, it will not work also.
Re: UHD drives
so basically if i got a drive tomorrow it will have to new firmwarejpsdr wrote:Yes if you have a 3.00, 3.01 or 3.02 firmware. Firmware 3.03 fix the loophole, and if you have an old disc with FW 1.xx, it will not work also.
can you downgrade the firmware?
Re: UHD drives
Probably not, because the last FW is very recent, and the whole process of fabrication, storage, sending to receler etc... takes time. So drive manufactured right now with FW 3.03 (and if drive manufactured right now are with FW 3.03) will probably not be in the market before a little while, but, don't take too long.
So right now, probably you'll get a disc manufactured not after half 2017, with a FW 3.01.
Recelers have to sell their stock before re-supply.
I've bought last week this drive in twice, one was manufactured half 2017 with FW 3.01, the other half 2016 with FW 3.00. So, if you buy your drive now, you'll not have a FW 3.03.
