UHD drives
hobbs47
Re: UHD drives
Post by hobbs47 »
aprosak wrote:
kingston12 wrote:
Is this currently the only UHD friendly external drive available? I'm running a laptop with no ability to expand it and buying a desktop is not an option.
I am in the same situation and I ended up going with the Asus BW-16D1HT with a Vantec external enclosure. Works like a champ.
hoppel118
Re: UHD drives
Post by hoppel118 »
Hi guys,
if I understand you right, my device would not work, because of the wrong service code. Is there any possibility to get this to work?
OS device name: F:
Product: BD-RE BH16NS40
Revision: 1.03
Serial number: K96F7UF5237
Firmware date: 2115-05-26 17:14:
Highest AACS version: 62
If not, I would buy an ASUS BW-16D1HT.
Regards Hoppel
TeddyRaspin
Re: UHD drives
Post by TeddyRaspin »
NS40 is not UHD friendly, I'm very sorry. :(
planet1
BUFFALO external slim UHD drives
Post by planet1 »
after buying a BRXL-PT6U2VB (manufactured November 2017), I was rather disappointed that the original FW BN10 (Date: 2017-05-30) was incapable of reading UHD blu-rays.
Flashing to the latest FW BN11 (Date: 2017-11-20) did not improve a thing.
Since the old FW v1.02 ought to be the same for numerous BUFFALO slim drives:
BRUHD-PU3
BRXL-PT6U3
BRXL-PT6U2V
DVSM-PTS58U2
DVSM-PT58U2V
is there any way to force flash this FW Version?
ArieS
Re: UHD drives
Post by ArieS »
jmonier wrote:WH14NS40 works fine for me. The Asus firmware can be loaded into it same as the WH16NS40.
Just got a WH14NS40 and I've been able to Rip Deadpool no problem.
However I was not able to rip Oblivion... The disc won't even open.
I tried to load the Asus 3.02 firmware that I got from Asus website called ASUS ODD FW Updater for BW-16D1HT.exe
But each time I press Start I get a popup saying: There is no target drive.
Am I missing something?
Thanks in advance, people :)
TeddyRaspin
Re: UHD drives
ArieS wrote: I tried to load the Asus 3.02 firmware that I got from Asus website called ASUS ODD FW Updater for BW-16D1HT.exe
Because no Asus drive is detected. You have to use the LG crossflash flasher and load the clean firmware.
I've written a specific guide to do that. https://www.makemkv.com/forum2/viewtopi ... 16&t=17058
ArieS
Re: UHD drives
Post by ArieS »
Wow, thanks Teddy for the great guide but it's really 'chinese' to me... This looks way too complicated for me.
I was hoping for an .exe and be done with it :(
TeddyRaspin
Re: UHD drives
Try this. Run the exe and select the firmware bin file (ASUS 3.02). :wink:
ArieS
Re: UHD drives
Post by ArieS »
Thank you Teddy!
The update went smoothly. Very appreciated and thank you for taking the time!
Even though it still cannot read Oblivion :cry: at least I have the last firmware which I've read helps my drive with speed...
TeddyRaspin
Re: UHD drives
@ArieS
Maybe your Oblivion UHD disc is a faulty one.
HerpoTheFoul
Re: UHD drives
Post by HerpoTheFoul »
I got a LG BH16NS55 manufactured in March 2017, ROM is 1.02 and SVC is NS55
I can't try it right now as I don't have the enclosure yet, but does it read them?
EDIT: Yes it does:
All BH16NS55 are SVC NS55
the WH16NS40 & BH16NS40 must have SVC NS50 to be UHD friendly. The NS40 drives have been around for years and were originally SVC NS40. The later one's from around the end of 2015 or early 2016, I believe are SVC NS50. All BH16NS55 are SVC NS55.
So, whenever someone is talking about having SVC NS50, they are referring to the WH16NS40 & BH16NS40 drives.
Bibio
Re: UHD drives
Post by Bibio »
i'm in the market for a new drive.
does the ASUS BW-16D1HT defiantly work copying 4k discs?
thanks
jpsdr
Re: UHD drives
Post by jpsdr »
Yes if you have a 3.00, 3.01 or 3.02 firmware. Firmware 3.03 fix the loophole, and if you have an old disc with FW 1.xx, it will not work also.
Bibio
Re: UHD drives
Post by Bibio »
jpsdr wrote:Yes if you have a 3.00, 3.01 or 3.02 firmware. Firmware 3.03 fix the loophole, and if you have an old disc with FW 1.xx, it will not work also.
so basically if i got a drive tomorrow it will have to new firmware :-(
can you downgrade the firmware?
jpsdr
Re: UHD drives
Post by jpsdr »
Probably not, because the last FW is very recent, and the whole process of fabrication, storage, sending to receler etc... takes time. So drive manufactured right now with FW 3.03 (and if drive manufactured right now are with FW 3.03) will probably not be in the market before a little while, but, don't take too long.
So right now, probably you'll get a disc manufactured not after half 2017, with a FW 3.01.
Recelers have to sell their stock before re-supply.
I've bought last week this drive in twice, one was manufactured half 2017 with FW 3.01, the other half 2016 with FW 3.00. So, if you buy your drive now, you'll not have a FW 3.03.
