Lady Bird correct mpls.
UsedKondomXL
Post by UsedKondomXL »
Anyone has the correct mpls for Lady Bird retail version ?
hvnphoto
Re: Lady Bird correct mpls.
Post by hvnphoto »
00964.MPLS
hvnphoto
Post by hvnphoto »
Title information
Source file name: 00964.mpls
Duration: 1:34:04
Chapters count: 16
Segment count: 15
Segment map: 514,504,506,508,512,507,503,501,511,505,509,513,515,502,510
File name: Lady_Bird_t221.mkv
Starhawk
Post by Starhawk »
Actually, I think this is the correct playlist. Can someone verify?
Title information
Name: Lady Bird (English)
Source file name: 00210.mpls
Duration: 1:34:04
Chapters count: 16
Segment count: 15
Segment map: 514,504,506,508,507,512,503,505,511,501,509,513,515,502,510
File name: Lady_Bird_t87.mkv
angelgraves13
Post by angelgraves13 »
It's 964
JediSamReye
Post by JediSamReye »
Yeah, I just finished watching 964. It is correct for my copy also
mkvgrub
Post by mkvgrub »
hvnphoto wrote:Title information
Duration: 1:34:04
Chapters count: 16
Segment count: 15
Mine for 964 has the same Segment map, but the File name is Lady_Bird_t01.mkv, and it is not in numerical order, but at the top of the list just after "File 00400.mpls was added as title #0"
Lovely Rita
Post by Lovely Rita »
Using Java runtime from /Library/Internet Plug-Ins/JavaAppletPlugin.plugin/Contents/Home/bin/java
Title information
Comment: FPL_MainFeature
Duration: 1:34:04
Chapters count: 16
Segment count: 15
File name: Lady_Bird_t01.mkv
Registered User :wink:
Buy MakeMKV
Starhawk
Post by Starhawk »
Thanks all.
When I play this from the file folder using PowerDVD, it plays 00210.mpls! For science, I rented it from iTunes to compare just to verify, and .00964 is correct.
preserve
Post by preserve »
mkvgrub wrote:Mine for 964 has the same Segment map, but the File name is Lady_Bird_t01.mkv, and it is not in numerical order, but at the top of the list just after "File 00400.mpls was added as title #0"
That's probably because MakeMKV names the files numerically in sequence, and the number of possible titles available for ripping will depend on your MakeMKV settings, namely the minimum duration setting. Also, I think MakeMKV is detecting it as a primary playlist in your case and placing it near the top.
Using: ASUS BW-16D1HT 3.00
dare7ab
Post by dare7ab »
Anyone know if the rental is same as retail for mpls?
get2brad
Post by get2brad »
dare7ab wrote:Anyone know if the rental is same as retail for mpls?
I have the Netflix disc. I was able to match the segment map from what others are saying is correct on the retail disc. I'm unsure if that means I found the correct one to extract.
Title information
Duration: 1:34:04
Chapters count: 16
Segment count: 15
File name: Lady_Bird_t03.mkv
I appreciate all those that contribute to these, I find them very helpful!
revidium
Post by revidium »
Is there a way to automatically de-select all the playlists? There must be 50 on this Lady Bird BD.
Post by d00zah »
Nothing automatic, but right-click on any title & select 'Unselect all' from the menu.
