When I updates to V1.12.0 to get uhd support, something new popped up in the menu system. Something like:
DTS-MA HD -> FLAC (lossless)
I would like to send the audio as pass though. Is there a way to disable the flac conversion?
Disable Flac for DTS-MA HD?
Re: Disable Flac for DTS-MA HD?
Ok for those that find this post later. What looks like is going on is that when I upgraded, it doubled the number of "Profiles" I have. Now MakeMKV doesn't load the default, because there is two of them. switching back to defalut (either one of them) Fixes the Flac issue
