The Hitman’s Bodyguard
cypherstrength
Re: The Hitman’s Bodyguard
Post by cypherstrength »
Nevermind 000999.mpls was at the top and not in numerical order. Me stoopid :P
Enjoy your day everyone!
Did it have a note next to it about being the "main feature"? Just want to make sure that MakeMKV is finding the right one when Java is installed.
cypherstrength
Woodstock wrote:Did it have a note next to it about being the "main feature"? Just want to make sure that MakeMKV is finding the right one when Java is installed.
Yes, it did. I went straight for looking for the correct mpls and didnt see it but it did show as the Main Feature towards the top of the list. It also listed some other stuff as well like trailers and outtakes I believe.
Kelvarr
Post by Kelvarr »
FWIW, the Family Video rental is the same as Netflix/Redbox.
cherishjoo
Post by cherishjoo »
Is 00648.MPLS equal to title 648?
Best Bluray DVD Ripping Solution
Not likely - title numbers in MakeMKV are assigned as eligible titles are found, and depend on your minimum length setting.
The name of the mpls is displayed in the Info window as you highlight a title in the left menu.
drathbun
Post by drathbun »
RamHawk wrote:Redbox / Netflix Versions:
Title information
Name: The Hitman's Bodyguard (English)
Comment: FPL_MainFeature
Source file name: 00999.mpls
Duration: 1:58:17
Chapters count: 16
Segment count: 10
Segment map: 506,507,502,508,504,509,501,503,510,505
Same segment map as the Retail version.
I have a retail package (4K + blu ray, attempting to rip the blu ray) and do not have this segment map at all. Can anyone confirm what the proper .mpls or segment map should be for this version?
cdhaiki
Post by cdhaiki »
This morning, I received a copy of the The Hitman’s Bodyguard Blu Ray from Amazon and after hand-verifying the flow of m2ts files, am confirming that the finding by hvnphoto of 00648.mpls for the US Retail version is still current.
Segment map: 503,509,504,506,510,501,502,505,507,508
FYI, file sizes are as follows:
   2445563904 00503.m2ts
    140685312 00509.m2ts
    153962496 00504.m2ts
   5392109568 00506.m2ts
    212453376 00510.m2ts
   8035104768 00501.m2ts
    123875328 00502.m2ts
   8742082560 00505.m2ts
    130977792 00507.m2ts
  13258942464 00508.m2ts
ajoconnor
Post by ajoconnor »
Hi everyone,
I have the buy your own version Blu-Ray version and once I installed java, it was a lot easier. I ripped it and the ran it through Handbrake. The version that MakeMKV selected and worked for me was:
Title information
Source file name: 00648.mpls
Duration: 1:58:17
Chapters count: 16
Segment count: 10
File name: The Hitman's Bodyguard-FPL_MainFeature_t02.mkv
Hope that helps!
