a "new MakeMKV instance" not working consistently (for me)
audioguy
Post by audioguy »
I must be dong something wrong. When I try to start up "a new MakeMKV instance" (on a Mac) it seems to try to connect to the drive that is already running with the first instance. It messes up the first instance and I have to close down the 2nd instance. It works sometimes so there must be an order in which to do thing to make it work all of the time.
HELP!
Re: a "new MakeMKV instance" not working consistently (for m
Preferences->IO, "Ask for single drive mode", check the box and click OK, restart MakeMKV.
