Obtaining FPL_MainFeature from console
lightsabersetc
#1 Post by lightsabersetc » Thu Oct 26, 2017 12:56 am
Is it possible to obtain the FPL_MainFeature comment that is present in the UI from within makemkvcon?
I've tried everything I can think of and have Google-fu'd myself to nowhere for an embarrassing amount of time, so I'm coming to believe it's not possible. Java is setup, with the console output confirming it:
MSG:3344,0,1,"Using Java runtime from /usr/lib/jvm/java-8-openjdk-amd64/bin/java","Using Java runtime from %1","/usr/lib/jvm/java-8-openjdk-amd64/bin/java"
This is definitely a title using playlist obfuscation, confirmed by this thread. For the sake of completeness, the output of
/usr/local/bin/makemkvcon --noscan info
for the known good track:
TINFO:356,2,0,"Saban's Power Rangers"
TINFO:356,8,0,"16"
TINFO:356,9,0,"2:03:58"
TINFO:356,10,0,"20.5 GB"
TINFO:356,11,0,"22076614656"
TINFO:356,16,0,"00886.mpls"
TINFO:356,25,0,"20"
TINFO:356,26,0,"514,505,502,517,510,503,515,509,504,516,508,506,513,520,512,518,511,519,501,507"
TINFO:356,27,0,"Saban's_Power_Rangers_t356.mkv"
TINFO:356,28,0,"eng"
TINFO:356,29,0,"English"
TINFO:356,30,0,"Saban's Power Rangers - 16 chapter(s) , 20.5 GB"
TINFO:356,31,6120,"<b>Title information</b><br>"
TINFO:356,33,0,"0"
SINFO:356,0,1,6201,"Video"
SINFO:356,0,5,0,"V_MPEG4/ISO/AVC"
SINFO:356,0,6,0,"Mpeg4"
SINFO:356,0,7,0,"Mpeg4"
SINFO:356,0,19,0,"1920x1080"
SINFO:356,0,20,0,"16:9"
SINFO:356,0,21,0,"23.976 (24000/1001)"
SINFO:356,0,22,0,"0"
SINFO:356,0,28,0,"eng"
SINFO:356,0,29,0,"English"
SINFO:356,0,30,0,"Mpeg4"
SINFO:356,0,31,6121,"<b>Track information</b><br>"
SINFO:356,0,33,0,"0"
SINFO:356,0,38,0,""
SINFO:356,0,42,5088,"( Lossless conversion )"
SINFO:356,1,1,6202,"Audio"
SINFO:356,1,2,0,"Surround 5.1"
SINFO:356,1,3,0,"eng"
SINFO:356,1,4,0,"English"
SINFO:356,1,5,0,"A_AC3"
SINFO:356,1,6,0,"DD"
SINFO:356,1,7,0,"Dolby Digital"
SINFO:356,1,13,0,"640 Kb/s"
SINFO:356,1,14,0,"6"
SINFO:356,1,17,0,"48000"
SINFO:356,1,22,0,"0"
SINFO:356,1,28,0,"eng"
SINFO:356,1,29,0,"English"
SINFO:356,1,30,0,"DD Surround 5.1 English"
SINFO:356,1,31,6121,"<b>Track information</b><br>"
SINFO:356,1,33,0,"90"
SINFO:356,1,38,0,"d"
SINFO:356,1,39,0,"Default"
SINFO:356,1,40,0,"5.1(side)"
SINFO:356,1,42,5088,"( Lossless conversion )"
SINFO:356,2,1,6202,"Audio"
SINFO:356,2,2,0,"Surround 5.1"
SINFO:356,2,3,0,"spa"
SINFO:356,2,4,0,"Spanish"
SINFO:356,2,5,0,"A_AC3"
SINFO:356,2,6,0,"DD"
SINFO:356,2,7,0,"Dolby Digital"
SINFO:356,2,13,0,"640 Kb/s"
SINFO:356,2,14,0,"6"
SINFO:356,2,17,0,"48000"
SINFO:356,2,22,0,"0"
SINFO:356,2,28,0,"eng"
SINFO:356,2,29,0,"English"
SINFO:356,2,30,0,"DD Surround 5.1 Spanish"
SINFO:356,2,31,6121,"<b>Track information</b><br>"
SINFO:356,2,33,0,"90"
SINFO:356,2,38,0,""
SINFO:356,2,40,0,"5.1(side)"
SINFO:356,2,42,5088,"( Lossless conversion )"
SINFO:356,3,1,6202,"Audio"
SINFO:356,3,2,5091,"Stereo"
SINFO:356,3,3,0,"eng"
SINFO:356,3,4,0,"English"
SINFO:356,3,5,0,"A_AC3"
SINFO:356,3,6,0,"DD"
SINFO:356,3,7,0,"Dolby Digital"
SINFO:356,3,13,0,"224 Kb/s"
SINFO:356,3,14,0,"2"
SINFO:356,3,17,0,"48000"
SINFO:356,3,22,0,"0"
SINFO:356,3,28,0,"eng"
SINFO:356,3,29,0,"English"
SINFO:356,3,30,0,"DD Stereo English"
SINFO:356,3,31,6121,"<b>Track information</b><br>"
SINFO:356,3,33,0,"90"
SINFO:356,3,38,0,""
SINFO:356,3,40,0,"stereo"
SINFO:356,3,42,5088,"( Lossless conversion )"
SINFO:356,4,1,6203,"Subtitles"
SINFO:356,4,3,0,"eng"
SINFO:356,4,4,0,"English"
SINFO:356,4,5,0,"S_HDMV/PGS"
SINFO:356,4,6,0,"PGS"
SINFO:356,4,7,0,"HDMV PGS Subtitles"
SINFO:356,4,22,0,"0"
SINFO:356,4,28,0,"eng"
SINFO:356,4,29,0,"English"
SINFO:356,4,30,0,"PGS English"
SINFO:356,4,31,6121,"<b>Track information</b><br>"
SINFO:356,4,33,0,"90"
SINFO:356,4,38,0,""
SINFO:356,4,42,5088,"( Lossless conversion )"
SINFO:356,5,1,6203,"Subtitles"
SINFO:356,5,3,0,"eng"
SINFO:356,5,4,0,"English"
SINFO:356,5,5,0,"S_HDMV/PGS"
SINFO:356,5,6,0,"PGS"
SINFO:356,5,7,0,"HDMV PGS Subtitles"
SINFO:356,5,22,0,"6144"
SINFO:356,5,28,0,"eng"
SINFO:356,5,29,0,"English"
SINFO:356,5,30,0,"PGS English  (forced only)"
SINFO:356,5,31,6121,"<b>Track information</b><br>"
SINFO:356,5,33,0,"90"
SINFO:356,5,38,0,"d"
SINFO:356,5,39,0,"Default"
SINFO:356,5,42,5088,"( Lossless conversion )"
SINFO:356,6,1,6203,"Subtitles"
SINFO:356,6,3,0,"spa"
SINFO:356,6,4,0,"Spanish"
SINFO:356,6,5,0,"S_HDMV/PGS"
SINFO:356,6,6,0,"PGS"
SINFO:356,6,7,0,"HDMV PGS Subtitles"
SINFO:356,6,22,0,"0"
SINFO:356,6,28,0,"eng"
SINFO:356,6,29,0,"English"
SINFO:356,6,30,0,"PGS Spanish"
SINFO:356,6,31,6121,"<b>Track information</b><br>"
SINFO:356,6,33,0,"90"
SINFO:356,6,38,0,""
SINFO:356,6,42,5088,"( Lossless conversion )"
SINFO:356,7,1,6203,"Subtitles"
SINFO:356,7,3,0,"spa"
SINFO:356,7,4,0,"Spanish"
SINFO:356,7,5,0,"S_HDMV/PGS"
SINFO:356,7,6,0,"PGS"
SINFO:356,7,7,0,"HDMV PGS Subtitles"
SINFO:356,7,22,0,"6144"
SINFO:356,7,28,0,"eng"
SINFO:356,7,29,0,"English"
SINFO:356,7,30,0,"PGS Spanish  (forced only)"
SINFO:356,7,31,6121,"<b>Track information</b><br>"
SINFO:356,7,33,0,"90"
SINFO:356,7,38,0,""
SINFO:356,7,42,5088,"( Lossless conversion )"
kenneth
Re: Obtaining FPL_MainFeature from console
#2 Post by kenneth » Tue Feb 20, 2018 4:56 am
Is this still a dead-end or did you find a solution?
BatchMKV - free Windows-based batch processing software for MakeMKV
lightsabersetc
#3 Post by lightsabersetc » Tue Feb 20, 2018 4:26 pm
Still a dead end on my side.
I’ve found a way to identify the correct track if you rip them all and use a script to compare frames, but it’s not really feasible outside of the lab because of the heavy processing required.
preserve
#4 Post by preserve » Tue Feb 20, 2018 6:24 pm
Are you using the latest version of MakeMKV?
Works just fine for me, although I don't have that particular movie ;)
Here is my super advanced batch script ;) in case anyone would like to use it.
for /f "tokens=1-5*" %%1 in ('vol d:') do ( set "volm=%%6" & goto done )
:done
dir d: /s >"%volm%-disc.txt"
e:\progra~1\makemkv\makemkvcon -r info disc:1 >"%volm%-tree.txt"
And the relevant parts of the result:
MSG:1005,0,1,"MakeMKV v1.12.0 win(x86-release) started","%1 started","MakeMKV v1.12.0 win(x86-release)"
DRV:1,2,999,12,"HD-DVD-ROM HL-DT-ST BDDVDRW GGC-H20L 1.03","THE_HUNGER_GAMES","D:"
MSG:3344,0,1,"Using Java runtime from E:\\Program Files\\Java\\jre1.8.0_144\\bin\\java.exe","Using Java runtime from %1","E:\\Program Files\\Java\\jre1.8.0_144\\bin\\java.exe"
TINFO:19,2,0,"The Hunger Games"
TINFO:19,8,0,"16"
TINFO:19,9,0,"2:22:33"
TINFO:19,10,0,"43.3 GB"
TINFO:19,11,0,"46582726656"
TINFO:19,16,0,"00800.mpls"
TINFO:19,25,0,"1"
TINFO:19,26,0,"450"
TINFO:19,27,0,"The_Hunger_Games_t19.mkv"
TINFO:19,28,0,"eng"
TINFO:19,29,0,"English"
TINFO:19,30,0,"The Hunger Games - 16 chapter(s) , 43.3 GB (FPL_MainFeature)"
TINFO:19,31,6120,"<b>Title information</b><br>"
TINFO:19,33,0,"0"
TINFO:19,49,0,"FPL_MainFeature"
Using: ASUS BW-16D1HT 3.00
