Re: 100% Firmware Downgrade for ASUS BW-16D1HT and LG BH16NS
Success
I had a LG WH16NS40 w/ a svc code of NS50 w/ a November 2017 manufacture date and 1.03 firmware
I followed the instructions dumping the firmware using the DOS method
I sent my dump to TeddyRaspin. And then was able to downgrade to 1.02 using a firmware he sent me, along with the "Flashing the firmware using the DOSFLASH modified method"
"Good" firmware are still in stock, just bought mine as bulk from amazon prime eu
Got firmware 3.01
Got firmware 3.01
- IMG_2018-02-19_18-40-14-bw.jpg (188.07 KiB) Viewed 56671 times
TeddyRaspin
Finally updated my own guide with the Windows Method for better use.
Has there been any further word on this? I'd love to wait for this solution rather than sell my LG external drive with bad firmware and take a chance on buying another drive.mike admin wrote: So while this method indeed works and produces amazing results, be very careful to follow the instructions closely. If unsure - just wait for more user-friendly tools to be released. There will be another announcement on this forum.
Hi guys, i hope to be in the "right" topic.
I have an ASUS BW-16D1H-U PRO, that should be the USB version of the BW-16D1HT.
I just upgraded the firmware to the new one, they called it FW A203, the stock one was the A201 (December 2016 manufactured).
Unfortunately there is no other FW to download from the Asus support site.
Can someone help me to find the flash tool with the A201 FW?
Thank you
Thank you
Unless something has changed in the last 90 days, the BW-16D1H-U series do NOT use the same drives as the SATA BW16s, and they are not BD-XL capable.
josephmyates
Hi you all,TeddyRaspin wrote: - Maybe someone could try, via DOSFLASH (the DOS modified version), to force to flash a NS50 firmware on a NS40 device and see if it works (after importing needed data, of course).
Just got a LG BH16NS40 (Oct 2015) SVC Code NS40
Has anyone been successful at flashing the NS50 firmware onto this NS40 device - and if so what's best way to do this?
Thanks!!
Does anyone happen to have a firmware file for a WH16NS40 with SVC tag of NS40? I made the mistake of trying to flash to the ASUS 3.02 firmware with this drive before I read about the SVC tag differences, and now the drive doesn't load any discs at all.
I don't think there is a way to do this successfully. I tried multiple times, and ended up bricking my drive (tray would open/close, but would not read any discs, even standard blu-rays or DVDs). I had to flash it back to v1.00 that I found for the NS40 tag using DOSFlash, then re-upgraded using the official LG flasher to get it working normally again.josephmyates wrote:Hi you all,TeddyRaspin wrote: - Maybe someone could try, via DOSFLASH (the DOS modified version), to force to flash a NS50 firmware on a NS40 device and see if it works (after importing needed data, of course).
Thanks!!
Report:
1. Asus BW-16D1HT purchased last week from Amazon
came with FW 3.00
Rips UHD perfectly, albeit slowly (about 3-4x). No failures yet on about 20 discs.
2. LG WH16NS40 svc code NS50 purchased this week from Amazon
came with FW 1.03
does NOT recognize UHD discs
Questions:
1. I am planning on downgrading the LG to 1.02; or should I cross flash to Asus 3.02?
2. Would I get any better read performance if I update the Asus to FW 3.02?
Thanks in advance.
came with FW 3.00
came with FW 1.03
Questions:
Thanks in advance.
alexcoluzzi32
So I'm hoping to do something with my WH16NS60 drive. Are these directions still my only option?
Thank you,
Alex
Thank you,
Alex
Firmware Downgrade On a Mac?
This is AMAZING, but has anyone successfully done this on a Mac? I'm thinking of trying:
1. USB FreeDOS stick
https://forums.macrumors.com/threads/ye ... ng.238190/ or https://honeypot.net/making-dos-usb-images-on-a-mac/
2. If worse comes to worst, install a VirtualBox and install Windows on it.
Anyone?
David
Anyone?
David
Re: Firmware Downgrade On a Mac?
Same question from me. I've bought an ASUS BW-16D1HT and one of these enclosures.davidahn wrote:This is AMAZING, but has anyone successfully done this on a Mac?
https://www.ebay.co.uk/itm/OWC-Mercury- ... rmvSB=true
Computer is a Mac Mini.
I just got the OWC case myself; VERY few ODD case options these days, as everyone's gone to thumb drives and those slim drives.B17NNS wrote:Same question from me. I've bought an ASUS BW-16D1HT and one of these enclosures.davidahn wrote:This is AMAZING, but has anyone successfully done this on a Mac?
What's your firmware version? Mine's 3.00 and works great. You just have to download the hashed keys and put them in your MakeMKV folder (the path is in your MakeMKV settings). My problem's with my LG drive.
Enclosure hasn't arrived yet so I don't know.davidahn wrote:What's your firmware version? Mine's 3.00 and works great. You just have to download the hashed keys and put them in your MakeMKV folder (the path is in your MakeMKV settings).
Manufacture date is September 2017.
