Script to rip DVD / Blu-ray from any source (iso, dir, dev)
beandog
Post by beandog » Sun Feb 18, 2018 7:47 am
Here's a script I wrote and use to rip all my stuff regardless of where it's at -- a device file, a directory, or an ISO I've already made, and will use the proper makemkvcon arguments.
Some example usages:
dvd_makemkv /dev/sr0
dvd_makemkv bluray.iso
dvd_makemkv /mnt/bluray
Here you go, hope this helps someone :)
#!/bin/bash
function is_dvd {
        device="$(realpath $1)"
        test "$device" == "/dev/sr0" || return 1
function is_image {
        test -d "$device" && return 1
        test "${device: -3}" == "iso" || return 1
function is_directory {
        test -d "$device" || return 1
device="$1"
test -z "$device" && device="/dev/sr0"
test -e "$device" || return 1
track="all"
test -z "$2" || track="`expr $2 - 1`"
output_dir="."
if [[ "${device: -3}" == "iso" ]]; then output_dir="${device:: -3}mux"; if ! -d "$output_dir"; then mkdir "$output_dir"; fi; fi
if [[ "${device: -4}" == "iso/" ]]; then output_dir="${device:: -4}mux"; if [[ ! -d "$output_dir" ]]; then mkdir "$output_dir"; fi; fi
device="$(realpath $device)"
makemkv_arg=
is_dvd "$device" && makemkv_arg="dev:${device}"
is_image "$device" && makemkv_arg="iso:${device}"
is_directory "$device" && makemkv_arg="file:${device}/VIDEO_TS"
test -z "$makemkv_arg" && exit 1
makemkvcon --minlength=0 mkv "$makemkv_arg" $track "$output_dir"
mrdonkey
Re: Script to rip DVD / Blu-ray from any source (iso, dir, dev)
Post by mrdonkey » Mon Jun 10, 2019 3:12 pm
Sorry to drag up an old thread but this iexactly what I need. Only thing is I am new to makemkv. How can set this to run in a docker container that i have running based on jlesage/makemkv?
