UHD playback on new VLC 3.0
Low Winter Sun
#1 Post by Low Winter Sun » Sat Feb 10, 2018 8:06 pm
Now with 4k, 8k and UHD support (10 and 12 bit video),etc..
VLC 3.0 "Vetinari" is a new major update of VLC.
VLC 3.0 activates hardware decoding by default, to get 4K and 8K playback!
It supports 10bits and HDR
VLC supports 360 video and 3D audio, up to Ambisoncics 3rd order
Allows audio passthrough for HD audio codecs
Can stream to Chromecast devices, even in formats not supported natively
Can play Blu-Ray Java menus: BD-J
VLC supports browsing of local network drives and NAS
https://www.videolan.org/vlc/releases/3.0.0.html
DavVador
Re: UHD playback on new VLC 3.0
#2 Post by DavVador » Sun Feb 11, 2018 9:44 am
Looks good, but i can't get the menu to be played with UHD backups.
At first it asked me to get java (which i did), and now it says it can read it and i should try without the menu option (it works without it).
Anyone tried and managed to get it working ?
Cave Man
#3 Post by Cave Man » Wed Feb 14, 2018 12:14 am
VLC3 still stutters on my MacBook Pro dual core i7 (2017 model). On the other hand, IINA (Mac only) plays 4k MKV rips with no trouble at all. It has hardware decoding of HEVC. It is now my go-to app for playback.
https://lhc70000.github.io/iina/
Low Winter Sun
#4 Post by Low Winter Sun » Fri Feb 16, 2018 1:02 am
Ironically my mac pro 2013 is playing back 24fps UHD movies with no frame skipping at all, but brand new imacs with hardware support built into the Intel chips are skipping frames.
This is loads better than VLC 2.0. I couldn't play UHD disks at all.
lcgrzy
#5 Post by lcgrzy » Mon Feb 19, 2018 8:58 pm
I tried it the day they released it, still can't play as smoothly as MPV or MPC.
gereral1
#6 Post by gereral1 » Sun Feb 25, 2018 11:52 pm
Hardware acceleration works on am rx470 but no hdr passes to TV. Madvr works fine.
keithl
#7 Post by keithl » Sun Jun 03, 2018 1:57 pm
I have latest VLC 3.03 on a I7-6700K with nVidia GTX-970 and when I play ,y 4K HDR rips I get a black video, but sound is fine, these rips play fine on my Shied to my 4K TV. My PC monitors are not 4K HDR, but I would think VLC would scale it and display it without HDR.
jmone
#8 Post by jmone » Mon Jun 04, 2018 9:07 am
FYI - If you are after a PC SW player that supports BD Menus (both BD and UHD) have a look at JRiver Media Center. Working well.
keithl
#9 Post by keithl » Thu Jun 07, 2018 1:26 am
When I try and play UHD with VLC on my computer I get audio and a black scree, plays fine on my TV and Shield.
#10 Post by SamuriHL » Thu Jun 07, 2018 3:17 am
jmone wrote:FYI - If you are after a PC SW player that supports BD Menus (both BD and UHD) have a look at JRiver Media Center. Working well.
I second this. It works very well indeed.
