Just Errors with New 1.12
TeddyRaspin
Re: Just Errors with New 1.12
Successfully backupped The Martian EXT. UHD with ASUS BW-16D1HT 3.00 firmware (maximum ripping speed 7.5x) and no errors at all.
Dabruce
Me too, at about 18x , Anydvd
TeddyRaspin
18x is impossible for any UHD device.
Dabruce
LOL OK 18mb/sec...
But i think this fw dont work with my drive, like the other one...
The drive has to have some Hardware issues, i think
Dabruce
OK, next try, Boston (Euro Version), makemkv
Starts with 15 M/sec
EDIT: After ONLY 44 mins Boston was ripped succesfully
Now, hmm, lets try Deadpool
EDIT2: DEADPOOL was ripped succesfully too, but at poor speed, about 3X
Now KingKong
EDIT3: GREAT , 3 in a row, lets see what tomorrow brings...
Now KingKong
ekpen49
Greetings:TeddyRaspin wrote:I can try to fix your BH16NS55 if you wish.
Try to follow my guide to create a valid firmware dump of the faulty BH16NS55.
I have this same LGBHNS55 ver 1.01.
I use this drive to create over 80+ dumps , then suddenly it just stopped detecting discs. It powers on, thats all.
How do I create a firmware dump for this drive ? Where is your guide ?
If you are in the U.S, can I send it to you ? I will pay to have you ship back to me.
You can PM if possible.
Thanks.
George.
TeddyRaspin
@ekpen49
My guide is here : http://www.makemkv.com/forum2/viewtopic ... 16&t=17058
You can do it from windows command prompt.
Download the devilclaw's flasher from here : https://github.com/devilsclaw/flasher/releases
(32 bit or 64 bit depending on your OS).
Then follow my guide. It is clear and easy.
Dabruce
Same with my old one. CDs were still detected, but no Blurays... Got a new one by LG, it was broken...ekpen49 wrote:Greetings:
TeddyRaspin
Did you try a dump of that unit ? Maybe I could have fixed it.
Dabruce
No this was the one i send back to LG to get the new one.
