MakeMKV v1.5.6 beta win(x64-release) started
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occured while issuing SCSI command A30..00200744100720..020A4E645BA38371C9529FFA4739DABE2D2 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occured while issuing SCSI command A30..00200744100720..09CB5040624253717B20995B2C177705350 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occured while issuing SCSI command A30..00200744100720..041E8965B63AE43A34E7683B51A621E03CD to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occured while issuing SCSI command A30..00200744100720..0C306DF73A79E8AC6ABDAD4F067C8E62B6B to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occured while issuing SCSI command A30..00200744100720..07AA56A635C0A28DB25487D3579873CD095 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occured while issuing SCSI command A30..00200744100720..024D96C28874C4A6AF54492970F228E785E to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - KEY NOT ESTABLISHED' occured while issuing SCSI command AD010..080002440 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occured while issuing SCSI command A30..00200744100720..05FE64025A6945020C2157205A58B0A3474 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occured while issuing SCSI command A30..00200744100720..04182AB827AB75CBA7BEF730005466361C9 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occured while issuing SCSI command A30..00200744100720..0507E64F27F92E9619B38B5177878B071E4 to device 'SPTI:\Device\CdRom1'
Error 'Scsi error - ILLEGAL REQUEST:COPY PROTECTION KEY EXCHANGE FAILURE - AUTHENTICATION FAILURE' occured while issuing SCSI command A30..00200744100720..0AB6FE51BE2048B35857FFAB776F546F903 to device 'SPTI:\Device\CdRom1'
=C
I also get errors reading dvds.  I don't have any other decryption programs running.  However, I was able to use MakeMKV with AnyDVD HD.  I used AnyDVD HD to copy the Bluray to my harddrive.  Then, I opened the decrypted folder structure with MakeMKV.  That worked but the .mkv has significant issues playing in VLC.  And the subs don't work..
I would like to be able to use MakeMKV without AnyDVD HD and use it properly.  Is there something I am missing?
						[Problem] Decrypting Bluray Disc
- Contact:
Re: [Problem] Decrypting Bluray Disc
Please tell what drive do you use, the model number and whether it is internal or external.
Alright.
It's a LITE-ON Black 4X BD-R 2X BD-RE 12X DVD+R 4X BD-ROM SATA Internal Blu-ray Burner 4X Blu-ray Burner Model DH-4B1S-08 from newegg.
It is internal. The model number is DH-4B1S-08.
I hope that information helps.
Any word on this issue?
