MakeMKV for already ripped BluRays?
dbox_andi
#1 Post by dbox_andi » Sat Jun 19, 2010 5:59 pm
Hello, I already ripped a lot of BluRays using AnyDVD. I now tested MakeMKV and it's much(!) faster then AnyDVD :D
Is there a way (instead of inserting a BR disc) to open my already ripped BluRay BDMV folders to create a MKV-file?
Thanks a lot
setarip_old
Re: MakeMKV for already ripped BluRays?
#2 Post by setarip_old » Sat Jun 19, 2010 6:33 pm
Hi!
Sure - as long as the folder contains ALL the requisite files and folders, simply click on the folder icon, select the folder containing the BluRay "package" of files and folders, click on the "BDMV" folder and then click on either of the two ".bdmv" files...
dbox_andi
#3 Post by dbox_andi » Mon Jun 21, 2010 3:46 am
YES! It works with the .bdmv files. Thank you very much.
I always tried to open one of the .ts-files located in the /BDMV/STREAM folder :?
setarip_old
#4 Post by setarip_old » Mon Jun 21, 2010 9:26 am
You're quite welcome ;>}
