Help a newbie!
jstaubin
Help a newbie!
Post by jstaubin »
My uhd would not copy to mkv, but I did manage to make a decrypted iso of 40.5gb When putting the iso into make mkv, I get a total gb divided among 8 titles in the top box, but in the bottom box I get the following:
MakeMKV v1.10.10 win(x64-release) started
The new version 1.12.0 is available for download at http://www.makemkv.com/download/
AACS directory not present, assuming unencrypted disc
Title #00017.mpls has length of 8 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00053.mpls has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00054.mpls has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00055.mpls was added as title #0
File 00100.mpls was added as title #1
Title #00004.m2ts has length of 11 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00008.m2ts has length of 6 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00010.m2ts has length of 56 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00014.m2ts has length of 23 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00015.m2ts has length of 50 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00016.m2ts has length of 29 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00092.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00093.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00132.m2ts has length of 10 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00133.m2ts has length of 4 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00134.m2ts was added as title #2
File 00136.m2ts was added as title #3
Title #00137.m2ts has length of 109 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00141.m2ts has length of 59 seconds which is less than minimum title length of 120 seconds and was therefore skipped
File 00142.m2ts was added as title #4
File 00143.m2ts was added as title #5
File 00144.m2ts was added as title #6
File 00145.m2ts was added as title #7
Title #00146.m2ts has length of 32 seconds which is less than minimum title length of 120 seconds and was therefore skipped
Title #00147.m2ts has length of 109 seconds which is less than minimum title length of 120 seconds and was therefore skipped
I also have the blu ray bdmv, cert, and makemkv folders. Can some one tell me how to convert one of these into a lossless mkv file?
Thanks for any help.
Re: Help a newbie!
Based just on what you posted, if you click the "MakeMKV", you'll end up with 8 MKV files, one of which will be a 29GB copy of the movie.
Did you get a different result?
jstaubin
Re: Help a newbie!
Post by jstaubin »
Ok, managed to make the eight files, then merged with toolnix, but instead of dolby atmos the sound files read 5 streams of ac-3 in media info. I have never seen atmos to show up like this. (By the way, have patience, I am a 72 year old lady who takes up weird hobbies!!)
preserve
Re: Help a newbie!
Post by preserve »
You don't need to merge the 8 files. Each file is a separate "title" on the disc. Some might be special features, trailers, etc. In this case, only the largest one is the main movie.
Once you've opened the disc with MakeMKV and you're seeing the list of titles to select which ones you want to rip (your screenshot above), click the arrow beside each title and you will see the audio tracks available for that title. You can select or deselect the ones you want or don't want.
Using: ASUS BW-16D1HT 3.00
jstaubin
Re: Help a newbie!
Post by jstaubin »
Thanks ever so much...didn't realize about the arrows. Perfect copy with atmos!!
