Error making full decrypted backup
inge4711
Post by inge4711 » Sun Feb 04, 2018 4:06 pm
I would like to make a decrypted backup of EXPENDABLES 3. I use the ASUS "User friendly" drive and MakeMKV 1.12.0 with the
actuals keys_hashed.txt file.
The decrypted backup starts without problems. After 18 files the backup stopped with a "Backup Error" at file 01000.mts.
No more information is shown.
If I try a encrypted backup, no error occurs, so that the disc should be ok.
Any suggestions for solving the problem?
Exist the possibility to skip the file?
Thanks in advance
Re: Error making full decrypted backup
Post by Woodstock » Sun Feb 04, 2018 4:19 pm
"Backup" really means "make a copy of the disk", so errors break it.
However, what happens if you do an encrypted backup from the disk, then open that with MakeMKV to make an decrypted backup?
inge4711
Post by inge4711 » Sun Feb 04, 2018 4:26 pm
Thanks for your reply. Yes I mean full backup.
When I first make an encrypted ISO, MakeMKV can not decrypt it.
inge4711
Post by inge4711 » Sun Feb 04, 2018 4:34 pm
Additionally if I make an encrypted full backup with MakeMKV, there is no possibility to open it in MakeMKV as a disc.
So only the main stream can be decrypted. This runs without errors.
preserve
Post by preserve » Sun Feb 04, 2018 4:47 pm
inge4711 wrote:if I make an encrypted full backup with MakeMKV, there is no possibility to open it in MakeMKV as a disc.
File / "Open files" and choose the discatt.dat file in the backup directory.
Using: ASUS BW-16D1HT 3.00
inge4711
Post by inge4711 » Sun Feb 04, 2018 4:51 pm
Sorry, but with this option I can not make a full backup of the disc with all m2ts files.
Or is there a possibility I did not see?
