jigsaw 4k disc
smartieyoung
jigsaw 4k disc
Post by smartieyoung » Tue Jan 30, 2018 5:23 am
I was just curious if anyone has seen released keys for the new Jigsaw movie? I got my new copy today and decided to back up an encrypted copy to my hard drive and I sent the .tgz file to mike so hopefully I wont have to wait too long. :wink:
preserve
Re: jigsaw 4k disc
Post by preserve » Tue Jan 30, 2018 5:47 pm
If it's not in KEYDB.cfg and its not in the hashed keys file... then no, nobody has keys for it.
Those are the only 2 sources of keys at this time (unless DeUHD supports this movie and you buy it, although they do not publish keys and just as Mike predicted ages ago, they've quickly become obsolete), so with your dump submission, you're sure to see it supported by MakeMKV soon.
Using: ASUS BW-16D1HT 3.00
smartieyoung
Re: jigsaw 4k disc
Post by smartieyoung » Tue Jan 30, 2018 6:02 pm
I'm glad I can help out with getting new titles supported by makemkv,I will continue to submit files as I can.Thanks fore the clarification.
preserve
Re: jigsaw 4k disc
Post by preserve » Tue Jan 30, 2018 6:45 pm
I feel so bad for anyone buying DeUHD that doesn't know about MakeMKV.
399€ (holy s***!) for the "Pro" version... that's their highest tier... and with that version, their software will let you process 6 discs per day!
If you only need to do 2 discs per day, you can get a real bargain with the 199€ "Standard" version!
gereral1
Re: jigsaw 4k disc
Post by gereral1 » Tue Jan 30, 2018 6:49 pm
I sent Mike dump file a couple days ago.
tibby
Re: jigsaw 4k disc
Post by tibby » Wed Jan 31, 2018 4:43 am
i did sent jigsaw uhd dump too like 7days ago
hope the key come out next update ;)
Re: jigsaw 4k disc
Post by mike admin » Sun Feb 04, 2018 12:26 am
Please re-submit with 1.12.0 per https://www.makemkv.com/forum2/viewtopi ... 315#p60315
gereral1
Re: jigsaw 4k disc
Post by gereral1 » Sun Feb 04, 2018 1:09 am
mike admin wrote:Please re-submit with 1.12.0 per https://www.makemkv.com/forum2/viewtopi ... 315#p60315
You should have jigsaw in 5 min thkyou
gereral1
Re: jigsaw 4k disc
Post by gereral1 » Sun Feb 04, 2018 6:48 pm
Says 2h 2min to make mkv of saw. speed is 2x on rom 8.9meg sec but still going......post back once mkv is made
gereral1
Re: jigsaw 4k disc
Post by gereral1 » Sun Feb 04, 2018 7:39 pm
Jigsaw worked with the latest update and hash file. Took 2 hrs to do. Must be the new protections causing a slow copy.
Here is the meta data.
Video
ID in the original source medium : 4113 (0x1011)
Format : HEVC
Codec ID : V_MPEGH/ISO/HEVC
Duration : 1 h 31 min
Bit rate : 72.0 Mb/s
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.362
Stream size : 46.3 GiB (95%)
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : SMPTE ST 2084
Mastering display color primaries : R: x=0.680000 y=0.320000, G: x=0.265000 y=0.690000, B: x=0.150000 y=0.060000, White point: x=0.312700 y=0.329000
Mastering display luminance : min: 0.0050 cd/m2, max: 1000.0000 cd/m2
Maximum Content Light Level : 1000 cd/m2
Maximum Frame-Average Light Level : 390 cd/m2
Audio
ID in the original source medium : 4352 (0x1100)
Format : Atmos / TrueHD
Codec ID : A_TRUEHD
Bit rate mode : Variable
Bit rate : 3 853 kb/s
Maximum bit rate : 3 171 kb/s
Channel(s) : Object Based / 8 channels
Channel positions : Object Based / Front: L C R, Side: L R, Back: L R, LFE
Sampling rate : / 48.0 kHz
Frame rate : 1 200.000 FPS (40 spf)
Bit depth : 24 bits
Compression mode : Lossless
Stream size : 2.47 GiB (5%)
Title : Surround 7.1
Language : English
Default : Yes
Forced : No
gereral1
Re: jigsaw 4k disc
Post by gereral1 » Sun Feb 04, 2018 7:52 pm
Just remember guys to buy the movies. Don't pirate and share. I buy EVERY one of my movies and play them on my htpc. When you start sharing online then you pass the line and I believe everyone that does breaks the law. 4k uhd is a wonderful video technology. It is nice to be able to use my kodi front end interface again with my pc to automate my movie experience. Atmos is wonderful as well.
tibby
Re: jigsaw 4k disc
Post by tibby » Tue Feb 06, 2018 1:25 am
i sent back jigsaw few hours ago ... its a different disc the one key that is there not working on that disc.... also sent another version of deepwater horizon not decrypted yet
smartieyoung
Re: jigsaw 4k disc
Post by smartieyoung » Tue Feb 06, 2018 1:33 am
i have also tried decrypting the whole disc with the latest hashed key file and it didnt complete the copy sucessfully.I will say this though i was able to do a encrypted disc backup and then use the key in the hashed file to decrypt that backup if that makes sense.I will also submit my logs to mike as well,perhaps there is something im not seeing.have a good night.
smartieyoung
Re: jigsaw 4k disc
Post by smartieyoung » Tue Feb 06, 2018 5:44 pm
My file ripped successfully and I was able to run it through a video converting software to make it easy to watch .If anyone has questions feel free to ask I would be more than happy to help.
:mrgreen:
tibby
Re: jigsaw 4k disc
Post by tibby » Wed Feb 07, 2018 3:14 pm
Hi i sent my dump of jigsaw over a week ago ... i know there is been a error and i sent my 2nd dump few days ago since then there was a few key update but still not my jigsaw key disc ...
my jigsaw disc is canadian version with french on it ... the one key available is for the us disc ... my disc still not decrypt since no key yet available. mike is there a problem with my dump files ?
thanks
