Optical Drive not being found
johna
Re: Optical Drive not being found
#76 Post by johna » Sat Feb 03, 2018 12:09 am
For those using LXC (containers) I was able to get 1.10.10 working by:
1. Adding additional devices.allow to <container>/conf for sg devices
lxc.cgroup.devices.allow = c 21:* rwm
2. Include creation of new node in my node creation script (called via lxc.hook.autodev):
mknod -m 666 ${LXC_ROOTFS_MOUNT}/dev/sg3 c 21 3
This is for a privileged container. Entries may be different for your environment.
aurik
#77 Post by aurik » Sat Feb 03, 2018 5:55 pm
Actually the easiest way to determine a) whether you have the "sg" driver loaded AND which sg device corresponds to your optical drive is to use the lsscsi command with the "-g" option:
root@media-srv:/export/src/makemkv# lsscsi -g
[0:0:0:0]    disk    ATA      ST1000LM024 HN-M 2AR1  /dev/sda   /dev/sg0
[1:0:0:0]    cd/dvd  HL-DT-ST BDDVDRW UH12NS29 1.00  /dev/sr0   /dev/sg1
[2:0:0:0]    disk    ATA      ST1000LM024 HN-M 2AR1  /dev/sdb   /dev/sg2
[3:0:0:0]    disk    ATA      ST1000LM024 HN-M 2AR1  /dev/sdc   /dev/sg3
[4:0:0:0]    disk    ATA      ST1000LM024 HN-M 2AR1  /dev/sdd   /dev/sg4
[5:0:0:0]    disk    ATA      ST1000LM024 HN-M 2BA3  /dev/sde   /dev/sg5
[6:0:0:0]    disk    ATA      ST1000LM024 HN-M 0001  /dev/sdf   /dev/sg6
[6:0:1:0]    cd/dvd  HL-DT-ST BDDVDRW UH12NS29 1.00  /dev/sr1   /dev/sg7
[6:0:2:0]    disk    ATA      OCZ-ONYX         1.7   /dev/sdg   /dev/sg8
[6:0:3:0]    disk    ATA      ST1000LM024 HN-M 0002  /dev/sdh   /dev/sg9
[6:0:4:0]    disk    ATA      ST1000LM024 HN-M 0001  /dev/sdi   /dev/sg10
[6:0:5:0]    disk    ATA      ST1000LM024 HN-M 0001  /dev/sdj   /dev/sg11
spl147
#78 Post by spl147 » Sun Feb 04, 2018 1:17 am
alexsd wrote:i'm at a loss here too. i've tried everything posted in this thread.
i'm on unraid 6.3.5.
can you take a look, mike?
root@Tower:~# ls -la /dev/sg*
crw-rw---- 1 root cdrom 21, 3 Jan 31 06:56 /dev/sg3
root@Tower:~# ls -la /dev/sr*
brw-rw---- 1 root cdrom 11, 0 Jan 31 06:56 /dev/sr0
you answered your own question
in the extra parameters section of the makemkv docker container put this:
--device /dev/sr0 --device /dev/sg3
the directions are in the docker container itself
#79 Post by mike admin » Sun Feb 04, 2018 3:37 pm
nickjpg wrote:Still waiting for "mike admin" to provide detailed instructions on his "simple fix".
Download 1.12.0
p.s. You do realize that "simple fix" were never my words?
spl147 wrote:it's a very simple fix,
spl147
#80 Post by spl147 » Sun Feb 04, 2018 3:39 pm
Download 1.12.0
yes sir, i did not realize i quoted you as such.
alexsd
#81 Post by alexsd » Mon Feb 05, 2018 5:04 pm
Djoss wrote:Are you running MakeMKV inside a docker container? If yes, then I recommend that you post your issue on the support thread (unRAID forum) of the container . An incorrect container configuration can prevent the detection.
this got me working. thank you.
alexsd
#82 Post by alexsd » Mon Feb 05, 2018 5:06 pm
correct. that's what got me going. thank you.
nickjpg
#83 Post by nickjpg » Tue Feb 06, 2018 3:53 am
Is there a solution for a non "docker container makemkv" ?
JohnJasonJordan
#84 Post by JohnJasonJordan » Tue Feb 06, 2018 8:57 pm
I just installed 1.12.0 on Xubuntu 14.04.5 and the problem with not seeing the optical drives has been resolved. Thanks to all!
nickjpg
#85 Post by nickjpg » Wed Feb 07, 2018 5:03 am
Just confirmed that 1.12.0 installed on Arch linux 3.16.0-4-amd64 works. Thank you!
beandog
#86 Post by beandog » Sun Feb 18, 2018 7:52 am
Just a heads up, if you're using Gentoo, you'll need SCSI generic support in your kernel built-in or as a module (sg). Look for CONFIG_CHR_DEV_SG
Device drivers -->
  SCSI device support -->
    <*> SCSI generic support
jw.slackware
#87 Post by jw.slackware » Sat Feb 24, 2018 12:40 pm
Hi, guys.
Thanks for the information on this problem.
I'm using makemkv-1.12.0 on slackware64-current (14.2).
On my case, I was able to solve this problem by modifying /etc/rc.d/rc.modules.local.
#/sbin/modprobe sg
--> /sbin/modprobe sg
elParaguayo
#88 Post by elParaguayo » Mon Feb 26, 2018 9:24 pm
Using "modprobe sg" works for me. Thank you.
I know we can load the sg module at boot by including it in /etc/modules-load.d however the arch wiki seems to suggest that udev rules should be used for handling module loading. Can someone provide an example of this?
elParaguayo
#89 Post by elParaguayo » Wed Feb 28, 2018 7:32 pm
I'll answer my own question. This is the udev rule that works for me:
SUBSYSTEMS=="scsi", DRIVERS=="sr", ATTRS{type}=="4|5", GROUP="optical", RUN="/sbin/modprobe -bv sg"
archlinuxgogo
#90 Post by archlinuxgogo » Wed Mar 14, 2018 10:39 pm
elParaguayo wrote:I'll answer my own question. This is the udev rule that works for me:
I registered for the site just to say
"Thank You!!"
Worked like a champ.
