Star Wars Complete Saga
nicolaidenmark
#1 Post by nicolaidenmark » Sat Feb 03, 2018 10:24 am
Hi all,
New here. MakeMKV is awesome software, however, I do have a problem.
I want to rip all the films with:
English Intro text
Danish subtitles for intro text, dialog and alien dialog
English subtitles for dialog and alien dialog
Not really sure what / when "Forced" comwe into play.
Which subs do I need?
Thanks,
Re: Star Wars Complete Saga
#2 Post by Woodstock » Sat Feb 03, 2018 12:08 pm
"Which subtitles" is complicated by the fact that each movie was mastered at a different time, and the "correct" subtitle track varies I made a list of the correct "forced" tracks for English, but have lost it. Some it was the first track, some it was either 6 or even 9. The same sort of mixing probably applies to other languages.
For me, though, it was simple - I have MakeMKV rip ALL the tracks, then sort them out later using VLC (play the movie, look for subtitles) and handbrake (encode the movie to a smaller size, incorporating the "proper" tracks found in VLC).
nicolaidenmark
#3 Post by nicolaidenmark » Sat Feb 03, 2018 12:12 pm
Come to think of it: I COULD perhaps rip all the subs- then watch (note down) the correct tracks, the reopen in MakeMKV and remove the ones, I do not want?
I saw your post on the English vers. Thank you for your post
#4 Post by Woodstock » Sat Feb 03, 2018 12:25 pm
If you're not encoding, you COULD use mkvmerge (search for mkvtoolnix, Google knows where it is) to write a copy with only the tracks you want, without ripping a second time.
nicolaidenmark
#5 Post by nicolaidenmark » Sat Feb 03, 2018 12:33 pm
Woodstock wrote:If you're not encoding, you COULD use mkvmerge (search for mkvtoolnix, Google knows where it is) to write a copy with only the tracks you want, without ripping a second time.
I'm not. I'll check it out, thanks.
EDIT: Bummer, it seems with the Danish realease, there's no subs for the Intro text. One has to choose Danish Intro text to get any kind of translation. Well, I don't need the subs per say, however, I think this is a let down for people who don't speak / understand English.
