Blu Ray Region B
wunderlong88
Blu Ray Region B
Post by wunderlong88 » Fri Feb 02, 2018 5:40 pm
I want to order El Cid on Blu Ray and it is region B/2. Will I be able to rip it on my pc with makemkv? I've done other blu rays but never one that was another region and wasn't sure.
preserve
Re: Blu Ray Region B
Post by preserve » Fri Feb 02, 2018 5:45 pm
I've never had an issue and I've done a ton of DVDs and Blu-rays that are a different region than my drive - usually UK discs.
When opening the disc, MakeMKV says "attempting to work around," and it always does.
Using: ASUS BW-16D1HT 3.00
wunderlong88
Post by wunderlong88 » Fri Feb 02, 2018 5:48 pm
TY
Post by Woodstock » Fri Feb 02, 2018 6:28 pm
BD region coding seems to actually be simpler than DVD - they simply put up a different main video according to the region of the player, that says "you can't play this on your player". The video itself isn't encoded any differently.
I have a number of BD titles "out of region", and MakeMKV didn't even log that it was an issue. DVDs, it logs...
