Asus BC-12D2HT
GoofeyGuy
Asus BC-12D2HT
Post by GoofeyGuy » Tue Jan 30, 2018 10:12 am
Any one have firmware 3.0.0 laying arround for this drive, my friend is an idiot and flashed his drive tjhe other day to 3.0.1 even though i told him alot of times not to do it, now it can't read UHD
TeddyRaspin
Re: Asus BC-12D2HT
Post by TeddyRaspin » Tue Jan 30, 2018 2:29 pm
Better thing he can do is to crossflash it to other similar devices (LG).
GoofeyGuy
Re: Asus BC-12D2HT
Post by GoofeyGuy » Tue Jan 30, 2018 4:39 pm
Thats yrue, was also my other sugestion to him, the problem is just, tht we can't seem to find any information on witch LG drive its build on
DracUK
Re: Asus BC-12D2HT
Post by DracUK » Wed Jan 31, 2018 5:21 pm
Ive got the drive (UK) with firmware 3.0 on it.If you point me to a util that will dump the firmware I will do it for you
TeddyRaspin
Re: Asus BC-12D2HT
Post by TeddyRaspin » Wed Jan 31, 2018 5:31 pm
DracUK wrote:Ive got the drive (UK) with firmware 3.0 on it.If you point me to a util that will dump the firmware I will do it for you
Try this :
32 BIT
64 BIT
Open an elevated command prompt and type :
flasher -D to display the Asus Drive ID.
Then type
flasher -d [drive id] -l firmware.bin 6 00000000 00200000
Then send me the firmware.bin and I'll do the rest for a proper firmware flash dump !!!
P.S.
You can download it also from https://github.com/devilsclaw/flasher/releases
GoofeyGuy
Re: Asus BC-12D2HT
Post by GoofeyGuy » Wed Jan 31, 2018 8:45 pm
Oh, that would be great, i know my "stupid" friend would be happy then
TeddyRaspin
Re: Asus BC-12D2HT
Post by TeddyRaspin » Thu Feb 01, 2018 5:06 pm
@DracUK
Please, if you have time and if you follow my instructions, do a firmware dump for our community. :wink:
TeddyRaspin
Re: Asus BC-12D2HT
Post by TeddyRaspin » Tue Feb 06, 2018 7:08 pm
@GoofeyGuy
Hi mate, if you (or your friend) need, I've the 3.00 firmware and I can create a working one for your friend. :wink:
GoofeyGuy
Re: Asus BC-12D2HT
Post by GoofeyGuy » Tue Feb 06, 2018 8:21 pm
TeddyRaspin wrote:@GoofeyGuy
Would be great, just tried myself with the 3.0.0 from myce, ended up killing the drive, but always a good thing dosflash could wake it to life again
TeddyRaspin
Re: Asus BC-12D2HT
Post by TeddyRaspin » Tue Feb 06, 2018 9:02 pm
Send me your dump or the one of your friend if you need a valid 3.00 firmware to be flashed.
GoofeyGuy
Re: Asus BC-12D2HT
Post by GoofeyGuy » Tue Feb 06, 2018 9:12 pm
Mail on route
TeddyRaspin
Re: Asus BC-12D2HT
Post by TeddyRaspin » Tue Feb 06, 2018 9:17 pm
Here we go.
Use DOSFLASH (modified version), erase and flash eeprom and report feedback please. :wink:
TEST300.ZIP
(1.11 MiB) Downloaded 1916 times
GoofeyGuy
Re: Asus BC-12D2HT
Post by GoofeyGuy » Wed Feb 07, 2018 1:31 pm
Just been at her house and flashed the drive, works like it shoud
xmenw
Re: Asus BC-12D2HT
Post by xmenw » Sat Jun 02, 2018 8:59 pm
Reviving an old topic, but did anyone have a clean 3.0 firmware for this drive, so I could use Teddy's rom EEPROM data mover to downgrade the firmware on my drive to 3.0.
mrtibbs
Re: Asus BC-12D2HT
Post by mrtibbs » Tue Jun 05, 2018 12:41 pm
Yes I'm also looking for a clean 300 firmware to flash with. I'll host it if need be with my dropbox account for others
