UHD drives
Locked
Re: UHD drives
Post by SamuriHL »
That won't work. You're going to need to use the modified dos flasher that Teddy made to flash it from a USB dos stick. I don't have a link handy but it may have been posted on this forum. I know it's on RedFox's forum for sure and I think myce posted it, as well, somewhere. It's not a super fun flashing process but it'll get you downgraded and working again.
Because you're desperate to get this working I dug up a link to Teddy's post on RedFox. Apologies for posting to another site.
https://forum.redfox.bz/threads/anydvd- ... ost-479615
Re: UHD drives
Post by SamuriHL »
That should get you up and running again with 1.02. Then you can cross flash if you so desire. But get it downgraded first.
rivey
Re: UHD drives
Post by rivey »
starmax wrote:Check page 6 of this thread:
http://www.makemkv.com/forum2/viewtopic ... 5&start=75
If you are referring to the answer "Asus 3.02 clean firmware with flasher (to allow crossflash or easy upgrade from previous versions)", I have tried that and I get "Write DRAM NG 05/24/00".
Any idea's?
rivey
Re: UHD drives
Post by rivey »
SamuriHL wrote:That should get you up and running again with 1.02. Then you can cross flash if you so desire. But get it downgraded first.
Will that work on a win10 machine? And will I have to remove all drives but the LG drive. If I must, I will do it but it is not fun. My only other desktop is working on a WD Red and won't be free for another 3 days.
Re: UHD drives
Post by SamuriHL »
It won't be a windows 10 machine when you boot from a DOS stick. ;) It'll be a DOS machine so yes, it'll work. I know that seems like I'm being glib but I'm being serious. You'll be booting DOS off the USB stick and running the patched dos flasher that allows the downgrade to work. Follow his directions and it'll work.
Re: UHD drives
Post by SamuriHL »
Ah, P.S. I forgot Teddy had to update the bin file. Use this bin file with those instructions and that flasher:
https://forum.redfox.bz/threads/anydvd- ... ost-479726
This has the proper data that needs to be flashed to read discs.
rivey
Re: UHD drives
Post by rivey »
SamuriHL wrote:Ah, P.S. I forgot Teddy had to update the bin file.
Thanks, I will be trying this today and report back on the results.
rivey
Re: UHD drives
Post by rivey »
Just tried this and it worked perfectly. Am trying with my Hacksaw Ridge UHD and it is working. On my Asus drive it would always fail. It is currently throwing errors but it has gotten farther than my Asus drive. The main point is that it now works and is reading UHD disks. Thanks for all the help.
starmax
Re: UHD drives
Post by starmax »
Mine arrived from Newegg today, funny.. I feel like I won something!
starmax
Re: UHD drives
Post by starmax »
Same UHD disc (Amazing Spider-man 2)
LG with 1.02 FM is getting about 25 M/s peak
ASUS with 3.01 FM is getting about 32 M/s peak
Will definitely be looking into x-flashing the LG before putting into the closet as a backup drive.
Veger69
Re: UHD drives
Post by Veger69 »
Can anyone confirm that this drive will work as long as I don’t upgrade the firmware?
https://www.bestbuy.com/site/lg-16x-ext ... Id=5450155
rivey
Re: UHD drives
Post by rivey »
Veger69 wrote:Can anyone confirm that this drive will work as long as I don’t upgrade the firmware?
It is not on the "friendly list" so I must assume that it will not work. Why not get a internal drive from the friendly list and an external case (USB).
sofakng
Re: UHD drives
Post by sofakng »
Just to let everybody know, I got my WH16NS40 from NewEgg (NJ warehouse) and it came with SVC code NS50 but ROM v1.03 (firmware?) and a date of 11/2017.
I'm going to install it tomorrow and downgrade it. I'm assuming even though it appears to have come with 1.03 that it can still be downgraded and work OK with UHD?
TeddyRaspin
Re: UHD drives
Post by TeddyRaspin »
You should first dump your 1.03 firmware before downgrading.
Anyway, it can be downgraded and made UHD friendly again.
rivey
Re: UHD drives
Post by rivey »
TeddyRaspin wrote:You should first dump your 1.03 firmware before downgrading.
For clarification, I was given the following two links that "TeddyRaspin" had posted and it did the job perfectly.
These posts will get you through the process perfectly.
Locked
