UHD Art and Museums
pbelo
UHD Art and Museums
Post by pbelo »
Sent Mike the dumps for 2 Glorious Documentaries recently released in Italy.
In UHD 4K these are fantastic movies for the Art lovers.
Each box brings 3D + 4K versions , 3D one is already ripped and also glorious to watch.
Rome Basilica and Uffizi Gallery in Florence.
Hope Mike can make keys to make rip and get iso or mkv file for playback.
https://www.amazon.it/gp/product/B06ZY3 ... UTF8&psc=1
and
https://www.amazon.it/gp/product/B06Y15 ... UTF8&psc=1
pbelo
Re: UHD Art and Museums
Post by pbelo »
My deep thanks to Mike for so quickly used dumps sent to make decrypt tags.
Unfortunately only decrypt tags did not solve my rip needs.
At first Disk was accepted by MakeMKV but backup failed , either with ‘ decrypt files ‘ ON or OFF.
Many SCSI errors showed up
Manufacturer: ASUS BW-16D1HT, Revision: 3.00
Firmware date: 2115-11-03 11:10: Bus encryption flags: 1F, Highest AACS version: 61
Disc Information
Label: FIRENZE E GLI UFFIZI 4K
Timestamp: 2017-04-10 11:16:12
Data capacity: 49.5 Gb , Disc type: BD-ROM UHD , Number of layers: 2,
Bus encryption flags: 80
MakeMKV v1.10.10 win(x64-release) started
Debug logging enabled, log will be saved as C:\Users\Pedro Belo/MakeMKV_log.txt
Backing up disc into folder "C:/Users/Pedro Belo/Videos/4K Video Downloader/backup/FIRENZE E GLI UFFIZI 4K"
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading 'BD-RE ASUS BW-16D1HT 3.00' at offset '33209909248'
DEBUG: Code 0 at k/2TXL4T.E(L/=/R:29401129
DEBUG: Code 0 at ?pG_jo(0b`9a)kJMZ(B:213136102
DEBUG: Code 0 at ?pG_jo(0b`9a)kJMZ(B:29396667
DEBUG: Code 0 at ZzqAVl_?b2TAxDF*uo1&:213133319
Encountered 36 errors of type 'Read Error' - see http://www.makemkv.com/errors/read/
Backup failed
Solution ?
Mike says :The simple workaround is to copy all files from the disc to the hard drive manually, without MakeMKV running. If you succeed in this, there is a fast and simple way to convert such copy into encrypted MakeMKV backup that can be opened by MakeMKV later. See our forum for details.
Problem : Did not Suceed ….Protected Disks DONT ALOW to copy - drag and drop on Win.
Some said in this forum
Start a backup, uncheck the decrypt option. OK
Let it run until it gets to the first m2ts file. OK
At that point, it has saved the disc code, which is a file called "discatt.dat". OK
Stop the backup, quit MakeMKV, delete the incomplete BDMV file from the backup folder and drag-and-drop the file BDMV from the disc to the folder. NOT POSSIBLE, ENCRYPTED –PROTECTED SET= DISK-DRIVE, DON’T ALLOW such copy drag -drop process.
Let it copy the file. NOT POSSIBLE
Then, eject the disc, start MakeMKV, select File>Open Files and navigate to and double click the discatt.dat file. MAKEMKV CANNOT OPEN .DAT FILES ONLY VIDEO FILES.
Any way out , any Hope to solve ??
Appreciate you guys expertise on this to let me know feedback.
Greetings from Portugal
Post by mike admin »
pbelo wrote:Problem : Did not Suceed ….Protected Disks DONT ALOW to copy - drag and drop on Win.
Where did you get this information?
pbelo
Post by pbelo »
by testing on my PC .
Have used AnyDVD with 100% sucess , so finish my work fine.
