Asus BC-12D2HT
Asus BC-12D2HT
Any one have firmware 3.0.0 laying arround for this drive, my friend is an idiot and flashed his drive tjhe other day to 3.0.1 even though i told him alot of times not to do it, now it can't read UHD
Re: Asus BC-12D2HT
Better thing he can do is to crossflash it to other similar devices (LG).
Re: Asus BC-12D2HT
Thats yrue, was also my other sugestion to him, the problem is just, tht we can't seem to find any information on witch LG drive its build on
Re: Asus BC-12D2HT
Ive got the drive (UK) with firmware 3.0 on it.If you point me to a util that will dump the firmware I will do it for you
Re: Asus BC-12D2HT
Try this :DracUK wrote:Ive got the drive (UK) with firmware 3.0 on it.If you point me to a util that will dump the firmware I will do it for you
32 BIT
64 BIT
Open an elevated command prompt and type :
flasher -D to display the Asus Drive ID.
Then type
flasher -d [drive id] -l firmware.bin 6 00000000 00200000
Then send me the firmware.bin and I'll do the rest for a proper firmware flash dump !!!
P.S.
You can download it also from https://github.com/devilsclaw/flasher/releases
Re: Asus BC-12D2HT
Oh, that would be great, i know my "stupid" friend would be happy then
Re: Asus BC-12D2HT
@DracUK
Please, if you have time and if you follow my instructions, do a firmware dump for our community.
Re: Asus BC-12D2HT
@GoofeyGuy
Hi mate, if you (or your friend) need, I've the 3.00 firmware and I can create a working one for your friend.
Re: Asus BC-12D2HT
Would be great, just tried myself with the 3.0.0 from myce, ended up killing the drive, but always a good thing dosflash could wake it to life againTeddyRaspin wrote:@GoofeyGuy
Re: Asus BC-12D2HT
Send me your dump or the one of your friend if you need a valid 3.00 firmware to be flashed.
Re: Asus BC-12D2HT
Here we go.
Use DOSFLASH (modified version), erase and flash eeprom and report feedback please.
- TEST300.ZIP
- (1.11 MiB) Downloaded 1748 times
Re: Asus BC-12D2HT
Just been at her house and flashed the drive, works like it shoud
Re: Asus BC-12D2HT
Reviving an old topic, but did anyone have a clean 3.0 firmware for this drive, so I could use Teddy's rom EEPROM data mover to downgrade the firmware on my drive to 3.0.
Re: Asus BC-12D2HT
Yes I'm also looking for a clean 300 firmware to flash with. I'll host it if need be with my dropbox account for others
