File metadata not saved when empty subtitles removed
jbartlett777
#1 Post by jbartlett777 » Sun Jan 28, 2018 11:12 pm
Windows version
For the past few versions through current version (1.10.10), ripping a blu-ray disk with only Forced subtitles checked which then are removed from the output stream for being empty, the file metadata for audio/video isn't saved. If I re-rip with the empty subtitle streams unchecked so none are removed, the metadata is saved.
Clarification: Metadata such as displaying the video length in Windows Explorer and the Details tab viewing the file's properties.
