Downton Abbey Season 5
dtblair
Post by dtblair » Wed Apr 15, 2015 8:25 pm
Anyone have information on the correct episodes for the season? There are multiples upon multiples for each disc
abmcconnell
Re: Downton Abbey Season 5
Post by abmcconnell » Thu Apr 23, 2015 6:41 pm
Hi, on the discs we own this appears to be the schema
Here is the correct episode list for all three discs. What a bloody pain this turned out to be.
Downton Abbey S5 Disc 1
EP1 802
EP2 631
EP3 709
All Episodes (Not Verified) 406
Downton Abbey S5 Disc 2
E04 457
E05 972
E06 334
E07 877 should be '887'
All Episodes (Not Verified) 521
Downton Abbey S5 Disc 3
E09 806 (was originally noted as E10)
E10 467 (was originally noted as E09)
All Episodes (Not Verified) 649
aharsh
Post by aharsh » Fri May 29, 2015 4:55 am
abmcconnell wrote:Hi, on the discs we own this appears to be the schema
EP1 802
EP2 631
EP3 709
E04 457
E05 972
E06 334
Hmm, I just loaded up Disk1 today and it doesn't look like those playlists map out to my disk.
802 doesn't exist
631 and 709 are the 5 chapter 9.4 gig titles
I have the American region disk, not sure if that's different from yours. Seems like the Slysoft peeps are having difficulties with these disks as well... https://forum.slysoft.com/showthread.ph ... S-Region-A)/page5&s=513146ac2e4fa0b24dc412a94d873f00
macseven77
Post by macseven77 » Fri Jul 03, 2015 6:12 pm
Thank you abmcconnell!!
This was most helpful :)
wsmeyer
Post by wsmeyer » Tue Dec 29, 2015 2:27 am
EP1 802
EP2 631
EP3 709
E04 457
E05 972
E06 334
There are only 9 episodes so is E09 and E10 supposed to be E08 and E09?
Would this be correct?
EP1 802
EP2 631
EP3 709
E04 457
E05 972
E06 334
E07 887
E08 806
E09 467
tindivall
Post by tindivall » Mon Aug 01, 2016 1:22 am
EP1 802
EP2 631
EP3 709
E04 457
E05 972
E06 334
E07 887
E08 806
E09 467
If you notice abmcconnell skips from E07 to E09 (so safe to assume just miss-typed numbers as you have pointed out only 9 episodes not 10)
@abmcconnell Thanks for the order!
DowntonFan
Post by DowntonFan » Fri Dec 09, 2016 11:50 pm
Thank You.
EP1 802
EP2 631
EP3 709
E04 457
E05 972
E06 334
PithyJim
Post by PithyJim » Fri Jun 30, 2017 7:39 pm
You Guys posted this a while ago......But I appreciate your efforts to provide information.
Thanks............................
I can VERIFY, Disk 1 Season 5 of Downton Abbey is as stated.
I played each episode (Chapter by chapter) on my DVD player, each chapter start matched the chapter start of
the MakeMKV files produced..............................
EP1 802
EP2 631
EP3 709
All Episodes 406
Jim S....................
Ditto for Disk TWO........................
wchouser3
Post by wchouser3 » Sun Jan 28, 2018 5:46 pm
I commend you on your hard work. May I inquire as to what method you used to figure this out. Surely you didn't rip every one of these playlists and watch them, ruling out the ones that play out of order.
C0C0B
Post by C0C0B » Mon Jan 28, 2019 9:35 am
I could be wrong but when you look at the source file names most of them have a duplicate (n) where n is some number. The ones he wrote all lack that. I didn't look at all the files but it looks like they follow this rule.
sbrower99
Post by sbrower99 » Sat Feb 09, 2019 9:08 pm
Thanks for the info!
Does anyone have the same info for season 6?
EMHOK
Post by EMHOK » Fri Jul 03, 2020 4:10 pm
Been very thrilled to date with how MakeMKV has allowed me to setup up and use my digital library. Am fairly new to it, but have gone through 100's of DVDs this week until I ran into this with the Limited Edition Downton Abbey Seasons 1-5 PBS Blu-Ray set (Original UK Edition).I am assuming it is the Source File Name (SFN) that corresponds with the referenced numbers for the episode (see below). Unfortunately, the numbering scheme on this set is not consistent with the info provided. For example the file 457 listed here suggests it is E4, on this set it is E6 (which appears to be by far the most frequent recurring file).
Info Example:
Title information
Name: Downton Abbey Season 5 Disc 2
Source file name: 00887.mpls
Duration: 0:49:46
Chapters count: 5
Segment count: 1
Segment map: 12
File name: Downton Abbey Season 5 Disc 2_t180.mkv
Interestingly, the first 4 seasons all had only one file per episode.
****EDIT****
I originally asked a couple of questions about resolving filename discrepancies and determining the file contents prior to having to rip the file to view it. I have since taken a clue from one of the other responders and scanned the files (using the down cursor key) to identify files that did NOT have a parenthetic number at the end (e.g. Source file name: 00887.mpls(1)). These numbers were always (1) or (2).
This method identified 7 unique files on the disk, 4 of which contained the unique episodes. This appears to be the most expedient method to at least narrow the options. Eliminated a couple of them based on size. Quit after I got the remaining files I was seeking, so I do not know what the two other files contained (4 episodes and 1 combined file). But this approach will make it easier for the disc 3 and discs of season 6. Thanks!
EMHOK
Post by EMHOK » Sat Jul 04, 2020 12:34 am
Interestingly, Disc 2 of season 6 contained only one file per episode, but discs 1 and 3 (Episodes 1,2,3,8,9,10) each contained over 200 files. None of the filenames on the these two season 6 discs had (n)'s appended to the end, so this method could not be utilized. Fortunately, the answer on this forum to this question about Season 6 provided the exact filenames corresponding to each episode on discs 1 & 3. Interesting phenomenon.
dg928367
Post by dg928367 » Thu Jan 07, 2021 3:52 am
I'm a MakeMKV noob and could use some help...
I've bought a NAS and am happily converting all my DVDs, 118 so far no issues. Until Downton Abbey Season 5 Original UK edition. I'm having troubles on all the discs but will discuss disc 1 here.
There are 3 episodes on the disc; it plays fine with VLC media player.
MakeMKV opens the disc with 7 titles. I found that title1=E02 and title2=E01. The problem is that the rest of the titles either have tons and tons of errors, and are copies of title1.
I don't see filenames with numbers like in the thread. Can anyone tell me what I'm doing wrong? Thanks!
sdashper
Post by sdashper » Mon Apr 12, 2021 6:42 pm
Many thanks to all the others on here who have sorted out the messy Downton Abbey Blu-Rays for Seasons 5, 6, and Bonus discs. (I think Seasons 1 - 4 were unaffected)
Recapping... The disc authors used trickery on most of these discs to overwhelm someone using a ripping tool like MakeMKV. They took one episode on each disc, took a section out of the middle, cut that into about 15 short segments, and then created maybe 50 *.mpls files, each with the segments randomly out of order. Only one of the .mpls files is the right one for an episode. Somehow your BluRay player can tell which one is the right one to play, but MakeMKV can't, so it lists maybe 200 titles to choose from. Some have used AnyDVD HD to figure out the correct files. Others have looked for patterns in the mess (like ignoring all the .mpls files with a trailing "(1)" or "(2)"). Other times, it's trial and error. If you rip the wrong file, it will play ok until it hits the section of scrambled segments, at which point the video will play scenes in the wrong order for a little while, and then it will end OK. This makes it tedious and time consuming but not impossible to rip the discs correctly. It becomes a "needle in a haystack" problem. Note that segments are much shorter than chapters. A bad version of the title might seem OK if you quickly flip through its 7 chapters. Segments are shorter (sometimes one minute or less), so a whole batch of them might only be 5-10 minutes of playback.
Below is a list of all the episodes in one place (for the next victim). Basically, you'll need to run through the LONG list of titles that MakeMVK presents. Pay attention to the Track Info window to the right. For example, Season 5 Episode 1, rip the title with source file name "00802.mpls" (or output file name ending with "t163").
Hope this helps.
Downton Abbey Season 5 Disc 1 (Blu-Ray 14 of 21)
SEASON 5 EPISODE 1
Name: Downton Abbey Season 5 Disc 1 (English)
Source file name: 00802.mpls
Duration: 1:09:32
Chapters count: 7
Segment count: 1
Segment map: 107
File name: Downton Abbey Season 5 Disc 1_t163.mkv
SEASON 5 EPISODE 2
Source file name: 00631.mpls
Duration: 0:49:47
Chapters count: 6
Segment count: 1
Segment map: 109
File name: Downton Abbey Season 5 Disc 1_t129.mkv
SEASON 5 EPISODE 3
Source file name: 00709.mpls
Duration: 0:49:46
Chapters count: 5
Segment count: 15
Segment map: 101,114,102,111,106,8,258,104,115,112,12,108,105,110,103
File name: Downton Abbey Season 5 Disc 1_t145.mkv
SEASON 5 EPISODE 1, 2, 3 COMBINED
Source file name: 00406.mpls
Duration: 2:49:06
Chapters count: 18
Segment count: 17
Segment map: 107,109,101,114,102,111,106,8,258,104,115,112,12,108,105,110,103
File name: Downton Abbey Season 5 Disc 1_t83.mkv
Downton Abbey Season 5 Disc 2 (Blu-Ray 15 of 21)
SEASON 5 EPISODE 4
Name: Downton Abbey Season 5 Disc 2 (English)
Source file name: 00457.mpls
Duration: 0:49:46
Chapters count: 5
Segment count: 1
Segment map: 104
File name: Downton Abbey Season 5 Disc 2_t90.mkv
SEASON 5 EPISODE 5
Source file name: 00972.mpls
Duration: 0:49:47
Chapters count: 5
Segment count: 1
Segment map: 114
File name: Downton Abbey Season 5 Disc 2_t203.mkv
SEASON 5 EPISODE 6
Source file name: 00334.mpls
Duration: 0:49:46
Chapters count: 5
Segment count: 15
Segment map: 115,111,2,112,106,107,108,113,103,110,102,625,109,13,15
File name: Downton Abbey Season 5 Disc 2_t69.mkv
SEASON 5 EPISODE 7
Duration: 0:49:46
Chapters count: 5
Segment count: 1
Segment map: 12
File name: Downton Abbey Season 5 Disc 2_t183.mkv
SEASON 5 EPISODES 4, 5, 6, 7 COMBINED
Source file name: 00521.mpls
Duration: 3:19:06
Chapters count: 20
Segment count: 18
Segment map: 104,114,115,111,2,112,106,107,108,113,103,110,102,625,109,13,15,12
File name: Downton Abbey Season 5 Disc 2_t102.mkv
Downton Abbey Season 5 Disc 3 (Blu-Ray 16 of 21)
SEASON 5 EPISODE 8
Name: Downton Abbey Season 5 Disc 3 (English)
Source file name: 00806.mpls
Duration: 1:09:53
Chapters count: 8
Segment count: 15
Segment map: 112,107,13,2,102,116,108,347,110,111,104,109,113,106,103
File name: Downton Abbey Season 5 Disc 3_t160.mkv
SEASON 5 EPISODE 9
Source file name: 00467.mpls
Duration: 1:37:36
Chapters count: 7
Segment count: 1
Segment map: 115
File name: Downton Abbey Season 5 Disc 3_t89.mkv
SEASON 5 EPISODES 8, 9 COMBINED
Source file name: 00649.mpls
Duration: 2:47:30
Chapters count: 15
Segment count: 16
Segment map: 112,107,13,2,102,116,108,347,110,111,104,109,113,106,103,115
File name: Downton Abbey Season 5 Disc 3_t127.mkv
Downton Abbey Season 6 Disc 1 (Blu-Ray 17 of 21)
SEASON 6 EPISODE 1
Name: Downton Abbey Season 6 Disc 1 (English)
Source file name: 00990.mpls
Duration: 1:09:33
Chapters count: 8
Segment count: 15
Segment map: 101,12,113,289,111,109,114,103,105,104,108,110,112,115,106
File name: Downton Abbey Season 6 Disc 1_t300.mkv
SEASON 6 EPISODE 2
Source file name: 00475.mpls
Duration: 0:49:27
Chapters count: 5
Segment count: 1
Segment map: 13
File name: Downton Abbey Season 6 Disc 1_t145.mkv
SEASON 6 EPISODE 3
Source file name: 00319.mpls
Duration: 0:49:34
Chapters count: 5
Segment count: 1
Segment map: 102
File name: Downton Abbey Season 6 Disc 1_t97.mkv
SEASON 6 EPISODES 1, 2, 3 COMBINED
Source file name: 00445.mpls
Duration: 2:48:36
Chapters count: 18
Segment count: 17
Segment map: 101,12,113,289,111,109,114,103,105,104,108,110,112,115,106,13,102
File name: Downton Abbey Season 6 Disc 1_t135.mkv
Downton Abbey Season 6 Disc 2 (Blu-Ray 18 of 21)
SEASON 6 EPISODE 4
SEASON 6 EPISODE 5
SEASON 6 EPISODE 6
SEASON 6 EPISODE 7
MakeMKV reads this disc normally
Downton Abbey Season 6 Disc 3 (Blu-Ray 19 of 21)
SEASON 6 EPISODE 8
Name: Downton Abbey Season 6 Disc 3 (English)
Source file name: 00354.mpls
Duration: 1:15:51
Chapters count: 9
Segment count: 15
Segment map: 105,115,108,13,113,112,109,102,107,114,111,110,103,106,104
File name: Downton Abbey Season 6 Disc 3_t102.mkv
SEASON 6 EPISODE 9
Source file name: 00317.mpls
Duration: 1:37:48
Chapters count: 10
Segment count: 1
Segment map: 2
File name: Downton Abbey Season 6 Disc 3_t86.mkv
SEASON 6 EPISODES 8, 9 COMBINED
Source file name: 00558.mpls
Duration: 2:53:39
Chapters count: 19
Segment count: 16
Segment map: 105,115,108,13,113,112,109,102,107,114,111,110,103,106,104,2
File name: Downton Abbey Season 6 Disc 3_t163.mkv
FAREWELL TO HIGHCLERE
Source file name: 00014.m2ts
Duration: 0:06:55
Segment count: 1
Segment map: 14
File name: Downton Abbey Season 6 Disc 3_t304.mkv
THE CARS OF DOWNTON
Source file name: 00015.m2ts
Duration: 0:11:03
Segment count: 1
Segment map: 15
File name: Downton Abbey Season 6 Disc 3_t305.mkv
CHANGING TIMES AT DOWNTON
Source file name: 00018.m2ts
Duration: 0:14:17
Segment count: 1
Segment map: 18
File name: Downton Abbey Season 6 Disc 3_t307.mkv
Downton Abbey Bonus Disc 1 (Blu-Ray 20 of 21)
CHARACTER DOCUMENTARIES (7)
DOWNTON ABBEY CREATORS' FAVORITE SCENES
Downton Abbey Bonus Disc 2 (Blu-Ray 21 of 21)
DOWNTON ABBEY SUPERCUTS
Name: Downton Abbey Bonus Disc 2 (English)
Source file name: 00001.mpls
Duration: 0:31:31
Chapters count: 9
Segment count: 9
Segment map: 13,14,15,18,19,8,17,20,21
File name: Downton Abbey Bonus Disc 2_t00.mkv
THE STORY OF DOWNTON ABBEY
Source file name: 00693.mpls
Duration: 1:39:10
Chapters count: 10
Segment count: 15
Segment map: 506,510,511,504,505,508,501,500,503,507,509,513,512,514,502
File name: Downton Abbey Bonus Disc 2_t212.mkv
