Hardware Error - 6726217728 and 6726221824
hstamp
Post by hstamp »
I am trying to rip a blu ray of Young Frankenstein but have been unsuccessful. I have been getting the following error codes but are unable to make sense of them:
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00049.m2ts' at offset '6726217728'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk6' at offset '6726217728'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk6' at offset '6726221824'
DEBUG: Code 1073741829 at N;87||f5zz=H&u>Wt_:121262969
DEBUG: Code 100927744 at N;87||f5zz=H&u>Wt_:121262969
DEBUG: Code 0 at =^M4rI33W2cx/\Cfg0*W:121263291
DEBUG: Code 0 at :Etg}tshH7JYI{stw<}i:121262302
DEBUG: Code 0 at =^M4rI33W2cx/\Cfg0*W:213130812
DEBUG: Code 3284286 at =^M4rI33W2cx/\Cfg0*W:29393286
DEBUG: Code 0 at g/>>m:Vzl/$+*U=='upDy:29398967
DEBUG: Code 0 at 4J^(03;JK{JV]^A[f8w:213132767
DEBUG: Code 0 at Vs}:"-;2z>L2Ii|%dZJD:29403222
DEBUG: Code 0 at 2Bwk\16/U&U(|x,c!:213131893
DEBUG: Code 0 at 2Bwk\16/U&U(|x,c!:121263406
DEBUG: Code 0 at 2Bwk\16/U&U(|x,c!:29393907
Error 'Scsi error - HARDWARE ERROR:TRACK FOLLOWING ERROR' occurred while reading '/BDMV/STREAM/00049.m2ts' at offset '6747389952'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk6' at offset '6747389952'
DEBUG: Code 3294624 at =^M4rI33W2cx/\Cfg0*W:29393286
Any advice on how to fix the error would be much appreciated!
Re: Hardware Error - 6726217728 and 6726221824
First step with errors like this is to clean the disk - a little bit of film on the surface can cause exactly what you're seeing.
But that just the most likely cause.
wsott1971
Post by wsott1971 »
I don't think this is the case... I am getting something like this...
Error 'Scsi error - HARDWARE ERROR:TIMEOUT ON LOGICAL UNIT' occurred while reading '/VIDEO_TS/VTS_01_1.VOB' at offset '1269463040'
Error 'Posix error - Input/output error' occurred while reading '/dev/rdisk2' at offset '1269463040'
DEBUG: Code 1073741829 at IlTF'UhY3^9[LC]7ie:121262969
DEBUG: Code 100941314 at IlTF'UhY3^9[LC]7ie:121262969
blah... blah... blah...
It was on a single disk so not the drive... and the drive ran fine after on several... I tried to clean still got it... then I sent that DVD back as defective... Then I bought another copy from a totally different place and got the same error... I don't think it is the drive or the disk (at least not the disk in an intentional way)...
Maybe some kind of copy protection? or maybe a combination of the disk burn and that drive just not liking it.
I find it odd.
When errors occur at the SAME PLACE on different disks, it is most likely a manufacturing defect that affected a particular lot. I've had that happen with one DVD set - two different sets and even the Netflix copy had a defect at the same location. I eventually got around that with a different disk drive.
The hardware time-out messages could be that the drive is continuing to attempt to read the disk, while the operating system has already given up.
This topic was originally about a Track Following Error, which isn't the same as a read error. TFEs can RESULT from a read error, though.
wsott1971
Post by wsott1971 »
Definitely Structure or Cell protection... on title one cell 8.
Sent it in... wonder why it can't handle it... Disk is old.
