My Little Pony..
kennova
My Little Pony..
Post by kennova » Wed Jan 17, 2018 2:47 pm
There is a thread about the Blu-Ray, but not the DVD. I have the Redbox version anyone know the track? There are 6 options and none seem to line up to the time when I play it in VLC.
Re: My Little Pony..
Post by d00zah » Wed Jan 17, 2018 3:07 pm
Don't know that I trust VLC for a runtime, but I DO trust IMDB...
1 hr 39 min (99 min)
http://www.imdb.com/title/tt4131800/tec ... tt_dt_spec
kennova
Post by kennova » Wed Jan 17, 2018 4:27 pm
I've ripped the first 3 that are large enough to be candidates and the first looks to be correct which is Track 8. The others have audio that's way off.
And yeah the runtime is 1:39:14 on the ripped track. Which is different from VLC (1:39:10) and IMDB which doesn't include seconds.
Title information
Source title ID: 25
Duration: 1:39:05
Chapters count: 16
Segment count: 2
Segment map: 4,7-23
File name: title08.mkv
reasonable
Post by reasonable » Sat Jan 27, 2018 2:42 am
kennova wrote:I've ripped the first 3 that are large enough to be candidates and the first looks to be correct which is Track 8. The others have audio that's way off.
Title information
Source title ID: 25
Duration: 1:39:05
Chapters count: 16
Segment count: 2
Segment map: 4,7-23
when i copy that file, i get a boatload of read errors
Saving 1 titles into directory K:/Video/_MY_LITTLE_PONY_B386
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_15_1.VOB' at offset '3543699456'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '3543699456'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_15_1.VOB' at offset '3543955456'
Error 'Scsi error - MEDIUM ERROR:L-EC UNCORRECTABLE ERROR' occurred while reading '/VIDEO_TS/VTS_15_1.VOB' at offset '3544084480'
Error 'OS error - STATUS_DEVICE_DATA_ERROR' occurred while reading '\Device\CdRom0' at offset '3544084480'
Failed to save title 8 to file K:/Video/_MY_LITTLE_PONY_B386/title08.mkv
Encountered 21 errors of type 'Read Error' - see http://www.makemkv.com/errors/dvdread/
0 titles saved, 1 failed
using the latest version, 1.10.10
the disk appears fine, but if you guys are having success, i'm supposing that it could be my particular disk?
Post by Woodstock » Sat Jan 27, 2018 5:15 am
While the program provides a link to the official description of read errors, most of us recommend this link: http://makemkv.com/forum2/viewtopic.php?f=8&t=15055
Read errors are a pain. Just this past week I had a disk that gave errors similar to what you received, right down to the drive going off-line for a while. Put the disk in a different drive, and zero read errors. I didn't even clean the disk between tries... it was just the difference in alignment of the laser that turned the disk from "bad" to "good".
Krawk
Post by Krawk » Tue Mar 06, 2018 5:13 pm
Moderns discs, Lionsgate especially, they have dummy bad sectors in place. My thread about "Escape Plan" which went unanswered, essentially has the same problem. My solution was Any Dvd. When I load Any Dvd it sees there are dummy bad sectors and fake titles and patches them out, then MakeMKV sees only the valid track and rips it correctly. I possibly could have figured it out on my own with MakeMKV but that was time consuming.
I know Mike is heavily focused on Bluray and UHD Bluray, which is fine I guess as that is my primary usage anyway. Maybe fake bad sector detection varies from disc to disc, or maybe it's something that could be whipped out in code to get MakeMKV support it?
