Compressing mkv files
lingenfr
Post by lingenfr »
I've seen this discussed, but no real solution. I've ripped my BD and now have 4 mkv files (Fringe Season 1). Yes the files are huge. I would like to be able to watch on my N810, etc and want to compress down to a smaller file size. Handbrake doesn't seem to know what to do with them. I tried Avidemux but it reads nearly all of the file and then fails with a message about internal codec vc1. I have searched and can't find any answers. Is there any information on compressing the mkv files produced by makemkv with a linux app/tool? Simply saying use handbrake is not an answer as the start button is grayed out when I select the mkv file. Thanks for any assistance.
crowfax
Re: Compressing mkv files
Post by crowfax »
This little how-to from skittle should help you:
http://www.makemkv.com/forum2/viewtopic.php?f=6&t=1313
skittle
Post by skittle »
Hi, as crowfax pointed: x264 with ffms2 input should be able to directly compress your video!
mux audio/subs from source with x264 output and your done :)
xchema
Post by xchema »
The best method, I think, is demux mkv and then compress video track with handbrake.
skittle
Post by skittle »
handbrake is just a front end to a (very outdated) x264.
