MakeMKV Source: BD-RE HL -DT -ST BD-RE BE16NU50 1.01
The Lazy Slug
#1 Post by The Lazy Slug » Thu Jan 25, 2018 8:13 pm
Apologises for what is probably a stupid question, but my new BE16NU50 is reported as the source in MakeMKV with 1.01 at the end.
Does this refer to the players firmware?
Many Thanks
GoofeyGuy
Re: MakeMKV Source: BD-RE HL -DT -ST BD-RE BE16NU50 1.01
#2 Post by GoofeyGuy » Thu Jan 25, 2018 8:43 pm
The Lazy Slug wrote:Apologises for what is probably a stupid question, but my new BE16NU50 is reported as the source in MakeMKV with 1.01 at the end.
Many Thanks
Yes it does, your drive have firmware 1.01
The Lazy Slug
#3 Post by The Lazy Slug » Thu Jan 25, 2018 9:57 pm
Many Thanks.
I didn't want to play with any software to check just in case I triggered an update.
smartieyoung
#4 Post by smartieyoung » Tue Jan 30, 2018 5:35 am
Ive got the same drive with FW 1.00 and it works great I don't see a need to change any FW or any cfg files.I have ripped several of the UHD discs that I own and they have ripped fine no real problems.I try to keep my make mkv version up to date and the hashed key file current.I just wanted to pass that along.
however i wonder if LG will try to force an update on this drive through windows update ?
audioguy
#5 Post by audioguy » Tue Feb 20, 2018 10:00 pm
My first LG drive had the version 1.01. I ordered an additional drive and it has 1.02. Will that work ripping 4K movies? Or do I need to downgrade firmware?
YourMJK
#6 Post by YourMJK » Fri Feb 23, 2018 4:19 pm
audioguy wrote:My first LG drive had the version 1.01. I ordered an additional drive and it has 1.02. Will that work ripping 4K movies? Or do I need to downgrade firmware?
I got one with 1.02 and it didn't work. It just ejected the disc after a few seconds.
TeddyRaspin
#7 Post by TeddyRaspin » Fri Feb 23, 2018 5:26 pm
You can downgrade it to 1.01 after proper firmware dump. :wink:
sonner
#8 Post by sonner » Fri Feb 23, 2018 10:32 pm
As Mike said in another post.... If your not comfortable using the current methods, just wait for more user-friendly tools to be released..:)
adalogue
#9 Post by adalogue » Sun Apr 01, 2018 3:38 pm
I've been digging and can't find the other thread with instructions. I also upgraded to 1.02 and need to re-flash to 1.01.
Can someone please post it?
Fingers crossed!
st4evr
#10 Post by st4evr » Tue Apr 03, 2018 2:59 am
adalogue wrote:I've been digging and can't find the other thread with instructions. I also upgraded to 1.02 and need to re-flash to 1.01.
Fingers crossed!
See this post:
http://www.makemkv.com/forum2/viewtopic ... 16&t=17058
adalogue
#11 Post by adalogue » Wed Apr 04, 2018 5:27 am
