How do I recover my authorization code.
ibantu
I haven't used my Mac software in many months. Today I needed to use the software and it asked for a code and it needed updating. The last time that I used the software was before the update to the newest Mac OS. How do I recover my code??? Thanks!
Re: How do I recover my authorization code.
Had you purchased a key? Avangate support will be able to recover a copy:
https://secure.avangate.com/support/?me ... te&lang=en
See sig for link to latest beta key.
If you still have your email from back then, search for a message from avangate.com, which is where the original code would have been sent from. Otherwise, email support@makemkv.com with your information and Mike can look it up.
