I can report:
MakeMKV also does NOT read ANY BD disks for LGEBH10LS30 drive (DVDs read OK);
All other BD rippers don't have a problem with it..
ken
Mac OSX 10.6.3
MakeMKV Drive Compatibility
- Contact:
Re: MakeMKV Drive Compatibility
It this an external or internal drive?
Ken take a look at my post, I was having a similar problem with a LG drive and changing the enclosure solved the problem.kenliles wrote:I can report:
ken
Mac OSX 10.6.3
Might be worth a shot.
http://www.makemkv.com/forum2/viewtopic.php?f=4&t=1336
Mike - yes it's an external drive and enclosure I just got from OWC;
thanks Noddy - that sounds like the exact issue I'm having - just ordered the Vantec enclosure - I'll report back here on the results - thanks again..
ken
ken
posting results - sure enough OWC enclosure was the problem recognizing BD disks; new Vantec NexStar enclosure works like a champ..thanks noddy
ken
ken
