Jigsaw
Jigsaw
U.S. Retail
Title information
Source file name: 00432.mpls
Duration: 1:31:56
Chapters count: 16
Segment count: 16
Segment map: 505,502,514,503,518,513,509,517,519,501,508,506,516,510,507,520
File name: Jigsaw_t173.mkv
						Title information
Duration: 1:31:56
Chapters count: 16
Segment count: 16
				twistednexus
Re: Jigsaw
Any info on the redbox version?  It doesn't have this playlist or this segment map.
				laseridiot
Re: Jigsaw
US Netflix DVD
Title information
Source file name: 00453.mpls
Duration: 1:31:56
Chapters count: 16
Segment count: 16
Segment map: 520,517,513,505,518,507,514,501,506,519,516,509,503,510,508,502
File name: Jigsaw_t187.mkv
						Title information
Duration: 1:31:56
Chapters count: 16
Segment count: 16
				Dave-n-Crys
Re: Jigsaw
Same as Netflix... playlist 453; I just finished watching it, worked fine!twistednexus wrote:Any info on the redbox version? It doesn't have this playlist or this segment map.
Re: Jigsaw
laseridiot wrote:US Netflix DVD
Title information
Duration: 1:31:56
Chapters count: 16
Segment count: 16
There is no 000453
Goes 00452 then 00455
The Closer You Get to The Meaning
The Sooner You Know that You're Dreaming
				laseridiot
Re: Jigsaw
We're you using a Netflix Blu-ray? The Blu-ray I got didn't have 00432, so I went and found it for myself, and the correct one for me was 00453.terryzx wrote:
There is no 000453
Re: Jigsaw
laseridiot wrote:We're you using a Netflix Blu-ray? The Blu-ray I got didn't have 00432, so I went and found it for myself, and the correct one for me was 00453.terryzx wrote:
There is no 000453
Yes i have the NetFlix Blu-Ray and no 000453
				laseridiot
Re: Jigsaw
terryzx wrote:Yes i have the NetFlix Blu-Ray and no 000453laseridiot wrote:We're you using a Netflix Blu-ray? The Blu-ray I got didn't have 00432, so I went and found it for myself, and the correct one for me was 00453.terryzx wrote:
There is no 000453
Weird. Try the following guide: https://www.makemkv.com/forum2/viewtopi ... =6&t=16251
That's what I used to rip.
Re: Jigsaw
hvnphoto wrote:U.S. Retail
Title information
Duration: 1:31:56
Chapters count: 16
Segment count: 16
How weird. MakeMKV was able to open the java script for me.
Re: Jigsaw
If your system has properly-configured Java installed, MakeMKV will sort the "main feature" to the top of the list, so you won't find it if you're looking in numeric order.
