Ubuntu can't play MKV files?
theophile
Re: Ubuntu can't play MKV files?
#16 Post by theophile » Thu Jun 17, 2010 3:40 am
Heh, well this is a first degree fiasco now, isn't it?
Try grabbing the Flight Sim demo video here:
http://samples.mplayerhq.hu/V-codecs/WVC1/
and see if it will play. If not, then the problem is with mplayer, your video setup, or both. If it does play... well let's cross that bridge if we come to it!
xchema
#17 Post by xchema » Fri Jun 18, 2010 12:22 am
If you are trying to play a wvc1 mkv use
-demuxer lavf
parameter with mplayer, that should work. If this don't work you need to tell the order of codecs to use. Here is my mplayer parameters (note I'm using Nvidia VDPAU, not valid for ati)
-vo vdpau -vc ffmpeg12vdpau,ffwmv3vdpau,ffvc1vdpau,ffh264vdpau, -demuxer lavf -channels 6 -af volnorm
It's a problem with the default demuxer, not an MakeMKV problem.
By the way VDPAU is incredible, very low cpu usage with a simply nvidia 8400 and total smooth video.
xchema
#18 Post by xchema » Thu Jul 29, 2010 10:47 am
thealtenbach wrote:Try vlc I think that mkv is a format that vlc loves , also latest divx player should render mkv files fine , but vlc is the best solution , in case all fail try power dvd works wonders with any kind of video but subtitles are its Achilles' heel , newest version supposed to be better but still sux
He is talking about ubuntu, not windows, I think you're on wrong forum ;-)
xchema
#19 Post by xchema » Tue Aug 03, 2010 1:29 pm
Again, please read the post and the forum you are reading, this is LINUX not Windows.
