(Solved) Hacksaw Ridge and Hidden Figures Won't Rip
rivey
#1 Post by rivey » Mon Jan 22, 2018 5:33 am
Just this afternoon, I received to new UHD discs from Amazon. I was able to rip the bluray discs for both Hacksaw Ridge and Hidden Figures but when I tried to rip the UHD versions to my 4K Movie directory, they would not rip. Tried multiple times. To verify there was nothing wrong with my new Asus drive, I tried to rip my copy of UHD Wonder Women and it worked perfectly. I checked and made sure that my copy of the decode file is the latest and it is.
This is the file created for each of the two discs
Hidden Figures
Debug log started at Mon Jan 22 03:12:07 2018 , written by MakeMKV v1.10.10 win(x64-release)
001005:0000 MakeMKV v1.10.10 win(x64-release) started
001004:0000 Debug logging enabled, log will be saved as C:\Users\bobsm/MakeMKV_log.txt
DEBUG: Code 2365587456 at omP%9smz[`wPuZ2':121270950
DEBUG: Code 2147483648 at omP%9smz[`wPuZ2':121264671
DAFD=PAAAADAAAAEABDQkEHwECAQ==
DCE=VPgERLwI6z0tXXlOkIPJpydPilXjXyHXk2zm8Rxpr3p3K/jdIRMN0Jfl7yNDl9d3Vu/3VZA03BFVOSVXifApqUIILq9wwRWB60mDIKFYTu10gdjwJ3bXTATtijqk60FHYpdwEfJ5CEHlzhLvwRfTeJidJ7K1vMhU/Q==
DCE=8N3MXcK2wvGlm1FMnPWelb4kuZoJ1BXsxrVOv6v7izBm0Gch4WP+OysNY7TRO25StVNrzMU1xrcUGWh3RIunk5dlIWe1RJ8oHasEcfkywCZhMLlhOkMzqTJ8iLWe+2snBjLiU3tv1wp4lLbeNwqejqdC3jMZade65w==
003332:0000 Saved AACS dump file as G:/Media/MKB20_v61_Hidden_Figures_32D7.tgz
003303:0000 The volume key is unknown for this disc - video can't be decrypted
001003:0020 DEBUG: Code 0 at -'Yv[.c18C}y)BxG:121264257
001003:0020 DEBUG: Code 0 at -'Yv[.c18C}y)BxG:121265890
DCE=N8hzKqS3eeSVLPPisJZYn7Z1mhcy2VGn9oiXn+gmGUm1t5lFm9CVGmOwYzxWxYt2p0yrHWB2LSVEa9Vyf46OKsdTQlSs086qqNs4ZyM9SERYUBaiSHisCNN9EoKHlFQ0KWDVj7Lcca95hvZ++0a8Gxlaxv+KNfAMZQ==
DCE=aGp/UZ8E+w7PzysOEzHskfbbISwv3Zgtn2Tf424xLi3ONNx1eIWXM/YdCYiPIwyO+NFVfmc421Mb/5T9L1qWosbDzyO+RdqD2TLdSverE7Z/aXLa2cbJ81RKoIjqoOYgOTTJnay9Dj4O+/HqK3JEdq3kLoRmwT2NAA==
003332:0000 Saved AACS dump file as G:/Media/MKB20_v61_Hidden_Figures_1827.tgz
Hacksaw Ridge
Debug log started at Mon Jan 22 03:22:33 2018 , written by MakeMKV v1.10.10 win(x64-release)
DCE=TdEFgiDvLToGcSB05ZrDZmmSU9aQY3tc27cjoEWODcPJzCc2GrF9sZ7UlveSQL/dINHe0AWAUCLx1/VBNqDprzz17IGXqIxc6udVlhIVugnWotRyBsHj5xuv4/H5ICEtPcc/5n4l2OBc4GEYPo5gQ5uv15WL3lASSQ==
DCE=rQ8txy3ExcdR1FppnCO9z3mKXOz6h1EUsk1obm/yeZPOeIa5Ii/D0MVNb6//g6ohg3jENz3Cpxr2IhD2MRaaUAoMlYqri4lreLv8XVjU2VTwJPgUej5pEeYdqq2HyVnlNXSt24rrD/rOLs70bm7ZuFBItL5l/6v2pg==
DISCID=DFC77FD1DE51F3554BF64DA4C03A10F1B56BA978
003307:0000 File 00100.mpls was added as title #0
003307:0000 File 00000.mpls was added as title #1
003307:0000 File 00015.mpls was added as title #2
003307:0000 File 00007.mpls was added as title #3
003307:0000 File 00008.mpls was added as title #4
003307:0000 File 00009.mpls was added as title #5
003307:0000 File 00005.mpls was added as title #6
003307:0000 File 00012.m2ts was added as title #7
003307:0000 File 00017.m2ts was added as title #8
003307:0000 File 00006.m2ts was added as title #9
003307:0000 File 00004.m2ts was added as title #10
003307:0000 File 00003.m2ts was added as title #11
003025:0000 Title #00000.m2ts has length of 1 seconds which is less than minimum title length of 5 seconds and was therefore skipped
003307:0000 File 00900.m2ts was added as title #12
003025:0000 Title #00018.m2ts has length of 0 seconds which is less than minimum title length of 5 seconds and was therefore skipped
003307:0000 File 00019.m2ts was added as title #13
003307:0000 File 00063.m2ts was added as title #14
003307:0000 File 00007.m2ts was added as title #15
003307:0000 File 00005.m2ts was added as title #16
003025:0000 Title #00999.m2ts has length of 4 seconds which is less than minimum title length of 5 seconds and was therefore skipped
003307:0000 File 00901.m2ts was added as title #17
001003:0020 DEBUG: Code 100941314 at O&lE"h]~9Ky~l{TX:121269823
DCE=//PyDikVuYTa/arBPC/n8NRsIteiAYir3nGdq4qrzkXQTTM9QAS+fIE7fdUfL9dSsAo49RUjlK+3uNOggejHOrn9PrCXH+TBUl4I0DkjbUeaYGjpByuz9H44Bh1CdBSjUobz0n5Auc331UjttMmfaKrQt7gZJ7ncJw==
DCE=oIoVZbx8uYFj9NNQr0k4v0JihUe4YAw+Z9qPrZGP4QNISpympGa91CMf2y+duvNZDQsG6EUagSUeMdrtO7iogGHi1joKEg/ly1zpRiqAiUnxgQZ1ORgGMH/M7RaVQNW8weCS3k5gOFtlY7ejCOGi+/Te4hDN6r9QBQ==
Found java version=1.8.0.151 path=C:\Program Files (x86)\Java\jre1.8.0_151\bin\java.exe
Found java version=1.8.0.72 path=C:\Program Files\CrashPlan\jre\bin\java.exe
003344:0000 Using Java runtime from C:\Program Files (x86)\Java\jre1.8.0_151\bin\java.exe
DISCID=EFD9B3BAC1C60C0F959A86CC7E924367C6036FB5
003307:0000 File 00006.mpls was added as title #0
003307:0000 File 00005.mpls was added as title #1
003307:0000 File 00004.mpls was added as title #2
003307:0000 File 00003.mpls was added as title #3
003307:0000 File 00002.mpls was added as title #4
003307:0000 File 00001.mpls was added as title #5
003307:0000 File 00009.mpls was added as title #6
003307:0000 File 00000.mpls was added as title #7
003307:0000 File 00008.mpls was added as title #8
003307:0000 File 00007.mpls was added as title #9
005014:0000 Saving 1 titles into directory G:/Media/4K Movies/Hacksaw Ridge
001003:0020 DEBUG: Code 3221225489 at |TiWa5.}m#P7X(=bStUvk:IDu:213131617
001003:0020 DEBUG: Code 3221225489 at `H;YWaXsR^@&s&Xe:29393953
001003:0020 DEBUG: Code 0 at bnwrrg&vX?:da[iQT:121266856
004007:0010 AV synchronization issues were found in file 'G:/Media/4K Movies/Hacksaw Ridge/Hacksaw_Ridge_t07.mkv' (title #8)
004008:0010 AV sync issue in stream 1 at 0:00:00 with duration of 0.666ms : encountered overlapping frame, audio skew is +0.666ms
004008:0010 AV sync issue in stream 2 at 0:00:00 with duration of 0.666ms : encountered overlapping frame, audio skew is +0.666ms
001003:0020 DEBUG: Code 100860416 at O&lE"h]~9Ky~l{TX:121269823
001003:0020 DEBUG: Code 101000192 at O&lE"h]~9Ky~l{TX:121269823
002003:0000 Error 'Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB' occurred while reading '/BDMV/STREAM/00000.m2ts' at offset '34025164800'
DEBUG: Code 101000192 at <!b*q}O_rKz>H_og#c:213130904
001003:0020 DEBUG: Code 101000192 at <!b*q}O_rKz>H_og#c:121262969
001003:0020 DEBUG: Code 0 at ea=uM]h^6`cRU[Qv b%?:29395034
001003:0020 DEBUG: Code 0 at ;EA:*F2K6iX9BEETdzP':29394045
001003:0020 DEBUG: Code 0 at ea=uM]h^6`cRU[Qv b%?:121262647
001003:0020 DEBUG: Code 16613850 at ea=uM]h^6`cRU[Qv b%?:213129593
001003:0020 DEBUG: Code 0 at hP$^MMa0>idfSa2WoWs-V:29399197
001002:0020 LIBMKV_TRACE: Exception: Error in p->FetchFrames(1,false)
005003:0000 Failed to save title 7 to file G:/Media/4K Movies/Hacksaw Ridge/Hacksaw_Ridge_t07.mkv
002023:0000 Encountered 1 errors of type 'Read Error' - see /errors/read/
error=0x06030200 count=1 name=Scsi error - MEDIUM ERROR:NO SEEK COMPLETE
Encountered 51 unclassified errors
error=0x06052400 count=51 name=Scsi error - ILLEGAL REQUEST:INVALID FIELD IN CDB
005004:0080 0 titles saved, 1 failed
Application exited at Mon Jan 22 05:15:18 2018
Since I have no idea what these are really saying, hopefully others here will know.
I will go to Best Buy tomorrow and get another UHD to try but since my Wonder Woman UHD does still work, I doubt that would be the problem.
preserve
Re: Hacksaw Ridge and Hidden Figures Won't Rip
#2 Post by preserve » Mon Jan 22, 2018 7:22 am
rivey wrote:003332:0000 Saved AACS dump file as G:/Media/MKB20_v61_Hidden_Figures_32D7.tgz
Assuming you have the latest hashed keys file and that it's in your MakeMKV data directory, this indicates that the key for this disc (version) is unknown. You need to send one of these files (it made two because you tried twice) to svq@makemkv.com, and the key for this disc will be supported in a future hashed keys file.
Using: ASUS BW-16D1HT 3.00
rivey
#3 Post by rivey » Wed Jan 24, 2018 2:00 am
My replacement copy of Hacksaw Ridge arrived this afternoon but still no joy.
I have been able to rip a couple of other UHD titles but this one won't do it. When I first put it in, it identified as Hacksaw Ridge but would not allow me to rip. After that, all it will tell me is no disc inserted. I guess I will have to return it to Amazon and buy a copy from Best Buy. Maybe it is just a bad run. Rather frustrating but until ripping UHD becomes more mainstream will just have to live with it. Am thinking to get a second friendly drive to see how that will work. I have a Asus so I will order an LG friendly and try that.
preserve
#4 Post by preserve » Wed Jan 24, 2018 3:33 am
Make sure that no other programs are trying to access your drive while MakeMKV is.
Try doing a disc backup first - without decryption - instead of ripping it.
rivey
#5 Post by rivey » Wed Jan 24, 2018 4:44 pm
preserve wrote:Make sure that no other programs are trying to access your drive while MakeMKV is.
Already checked this. Set drive for no auto open and no default programs. Will keep trying.
rivey
Re: (Solved) Hacksaw Ridge and Hidden Figures Won't Rip
#6 Post by rivey » Mon Jan 29, 2018 3:50 am
Just got the new hack file and am now able to rip "Hidden Figures". Thanks for adding the new hack from the file I sent in. You are the best.
As for "Hacksaw Ridge", after trying the second disk, I have come to realize from the error log that the hack file will decode the UHD drive but the issue lies in my Asus drive. The disc and the drive don't seem to like each other. I am going to wait a while and order one of the LG drives and try that.
Thanks again for all the great work and support for MakeMKV.
Is there a way to donate to MakeMKV team to compensate for all their hard work? If there is not, there should be.
Lovely Rita
#7 Post by Lovely Rita » Mon Jan 29, 2018 4:16 am
rivey wrote: Is there a way to donate to MakeMKV team to compensate for all their hard work? If there is not, there should be.
There sure is!
/buy/
Registered User :wink:
Buy MakeMKV
rivey
#8 Post by rivey » Mon Jan 29, 2018 7:22 am
There sure is!
/buy/
Already did that two months ago. Still think it would be good to have a way to support this ongoing project. Just my 2 cents.
