Asus BW-16D1HT Firmware
bluntandrolla
Re: Asus BW-16D1HT Firmware
- ASUS_Website_FW_Updater_For_BW_16D1HT_FW_3.03.zip
- (1.43 MiB) Downloaded 2175 times
bluntandrolla
you can downflash , and I hope the loophole fix will be erased "fingercrossed"TeddyRaspin wrote:Could you provide us a valid link for testing the 3.03 firmware version ?barrett70 wrote:Hi, does anyone have any information about the 3.03 just released?
UHD or not?
Thanks.
Edit:
I've found it on Asus website (support page) and I've flashed it and I have to say few words:
"Be Aware from 3.03". It fixed the AACS loophole making your drive unable to read UHD discs !!!!
Now I've to use DosFlash and reflash the old firmware, with the hope it will read UHDs again.
TeddyRaspin
I've used now my dosflash modded DOS version and I've successfully flashed the old backup firmware.
Now I can read UHD discs again.
bluntandrolla
great news , now 3.03 is fucked and loophole fixerTeddyRaspin wrote:I've used now my dosflash modded DOS version and I've successfully flashed the old backup firmware.
Was this achieved using the programs in the zip file you posted over at the Redfox forums a while back + a dump of the original firmware?TeddyRaspin wrote:I've used now my dosflash modded DOS version and I've successfully flashed the old backup firmware.
So 3.02 is still good but 3.03 is a killer?
ron spencer
I have 3.01...can anyone point me to 3.02, which I guess is the last "safe" version to use. Are people ripping UHD fine with 3.02. I'd just like to be sure.
thx
thx
TeddyRaspin
You can find it here.ron spencer wrote:I have 3.01...can anyone point me to 3.02, which I guess is the last "safe" version to use. Are people ripping UHD fine with 3.02. I'd just like to be sure.
thx
ron spencer
Thanks. Just to verify, 3.02 is safe for UHD ripping? Thanks.TeddyRaspin wrote:You can find it here.ron spencer wrote:I have 3.01...can anyone point me to 3.02, which I guess is the last "safe" version to use. Are people ripping UHD fine with 3.02. I'd just like to be sure.
thx
ron spencer wrote:Thanks. Just to verify, 3.02 is safe for UHD ripping? Thanks.
yes it is, but its also the last there are safe
Yes, 3.02 is the LAST firmware update you will ever take on that drive. Do NOT do anything beyond it.
Can you describe the procedure you used to crossflash your LG's?jmone wrote:I have 2 x LG WH16NS55. I've crossflashed one to 3.00 and one to 3.02. Both are ripping fine with MakeMKV. I'll do a speed comparison later on which one (if either) is faster.
There is a really good guide hererivey wrote:Can you describe the procedure you used to crossflash your LG's?jmone wrote:I have 2 x LG WH16NS55. I've crossflashed one to 3.00 and one to 3.02. Both are ripping fine with MakeMKV. I'll do a speed comparison later on which one (if either) is faster.
https://translate.googleusercontent.com ... 9kKds09DZA
Just tried this and get the message "Write DRAM NG 05/24/00".Badnews wrote:chev3 wrote:Which Software you guys use to flash the Asus Drive?
If you want to flash your drive from 3.01 to 3.00 this modified flasher and bin file will do it from link below
http://www84.zippyshare.com/v/7MsNUYNo/file.html
For more NFO read this for Asus and LG Drives
https://forum.cdrinfo.pl/f29/crossflash-blu-ray-lg-serii-ns50-ns51-ns55-ns58-96313/
My operating system is Windows10 64bit.
Any ideas for solving this?
