Asus BW-16D1HT Firmware
bluntandrolla
Re: Asus BW-16D1HT Firmware
Post by bluntandrolla »
https://www.asus.com/us/Optical-Drives- ... _Download/
DO NOT UPDATE 3.03 IF YOU WANT TO READ UHD
ASUS_Website_FW_Updater_For_BW_16D1HT_FW_3.03.zip
(1.43 MiB) Downloaded 2187 times
bluntandrolla
TeddyRaspin wrote:
barrett70 wrote:Hi, does anyone have any information about the 3.03 just released?
UHD or not?
Thanks.
Could you provide us a valid link for testing the 3.03 firmware version ?
Edit:
I've found it on Asus website (support page) and I've flashed it and I have to say few words:
"Be Aware from 3.03". It fixed the AACS loophole making your drive unable to read UHD discs !!!!
Now I've to use DosFlash and reflash the old firmware, with the hope it will read UHDs again.
you can downflash , and I hope the loophole fix will be erased "fingercrossed"
TeddyRaspin
Post by TeddyRaspin »
I've used now my dosflash modded DOS version and I've successfully flashed the old backup firmware.
Now I can read UHD discs again. :wink:
bluntandrolla
TeddyRaspin wrote:I've used now my dosflash modded DOS version and I've successfully flashed the old backup firmware.
great news , now 3.03 is fucked and loophole fixer :)
mmmkv
Post by mmmkv »
Was this achieved using the programs in the zip file you posted over at the Redfox forums a while back + a dump of the original firmware?
Deraga
Post by Deraga »
So 3.02 is still good but 3.03 is a killer?
barrett70
Post by barrett70 »
Yes quite.
ron spencer
Post by ron spencer »
I have 3.01...can anyone point me to 3.02, which I guess is the last "safe" version to use. Are people ripping UHD fine with 3.02. I'd just like to be sure.
thx
TeddyRaspin
ron spencer wrote:I have 3.01...can anyone point me to 3.02, which I guess is the last "safe" version to use. Are people ripping UHD fine with 3.02. I'd just like to be sure.
thx
You can find it here.
ron spencer
thx
Thanks. Just to verify, 3.02 is safe for UHD ripping? Thanks.
GoofeyGuy
Post by GoofeyGuy »
ron spencer wrote:Thanks. Just to verify, 3.02 is safe for UHD ripping? Thanks.
yes it is, but its also the last there are safe
Post by SamuriHL »
Yes, 3.02 is the LAST firmware update you will ever take on that drive. Do NOT do anything beyond it.
rivey
Post by rivey »
jmone wrote:I have 2 x LG WH16NS55. I've crossflashed one to 3.00 and one to 3.02. Both are ripping fine with MakeMKV. I'll do a speed comparison later on which one (if either) is faster.
Can you describe the procedure you used to crossflash your LG's?
GoofeyGuy
Post by GoofeyGuy »
There is a really good guide here
https://translate.googleusercontent.com ... 9kKds09DZA
rivey
Post by rivey »
Badnews wrote:
chev3 wrote:Which Software you guys use to flash the Asus Drive?
If you want to flash your drive from 3.01 to 3.00 this modified flasher and bin file will do it from link below
http://www84.zippyshare.com/v/7MsNUYNo/file.html
For more NFO read this for Asus and LG Drives
https://forum.cdrinfo.pl/f29/crossflash-blu-ray-lg-serii-ns50-ns51-ns55-ns58-96313/
Just tried this and get the message "Write DRAM NG 05/24/00".
My operating system is Windows10 64bit.
Any ideas for solving this?
