I'm noticing this error on makeMKV 1.5.6 on Ubuntu 10.10 development branch: When streaming movies they hang after a few seconds regardless of the player and/or codec backend (gstreamer/ffmpeg) used. I tried recompiling MakeMKV as well as VLC but the error stayed. When I wanted to test a previous version of MakeMKV which worked perfectly I couldn't find the sources to download anymore
When I rip the BDs and make a MKV file, they play just fine.
Always the latest one via git-checkout. ffmpeg is also kept up-to date at least twice a month fresh from upstream's svn. However, as I wrote, the same problem exists in programs using gstreamer like totem (which I don't build myself so I can rule that out as a source of the problem) and (s)mplayer which is also kept up-to-date by myself.
Found a copy of 1.5.4's sources on my backintime-backup drive and everything works again, so I'd say this is a regression introduced between 1.5.5 and 1.5.6 (I remember 1.5.5 as working)
Okay, I found the culprit. I switched to the 2.6.35-rc-series about the time when I installed MakeMKV 1.5.6 - reverting to kernel 2.6.34 fixes the problem for me.
Sorry I didn't get back to you, real life got in the way! Anyway, glad you have it fixed.
No problems. Anyway the real trouble begins now hunting down the real bug (regression) in the kernel - I've never done a git bisect on a project as big as the kernel itself
