Streaming hanging after a few seconds
moviemaniac
#1 Post by moviemaniac » Thu Jun 17, 2010 7:59 pm
I'm noticing this error on makeMKV 1.5.6 on Ubuntu 10.10 development branch: When streaming movies they hang after a few seconds regardless of the player and/or codec backend (gstreamer/ffmpeg) used. I tried recompiling MakeMKV as well as VLC but the error stayed. When I wanted to test a previous version of MakeMKV which worked perfectly I couldn't find the sources to download anymore :(
When I rip the BDs and make a MKV file, they play just fine.
Any ideas?
crowfax
Re: Streaming hanging after a few seconds
#2 Post by crowfax » Thu Jun 17, 2010 8:35 pm
Which version of VLC are you using?
Media Box: Ryzen 5700x / Arc A380, Windows 11, BU40N, BW-16D1HT, BP60NB10
Playback Devices: Nvidia Shield Pro, Apple TV 4k
moviemaniac
#3 Post by moviemaniac » Thu Jun 17, 2010 8:43 pm
Always the latest one via git-checkout. ffmpeg is also kept up-to date at least twice a month fresh from upstream's svn. However, as I wrote, the same problem exists in programs using gstreamer like totem (which I don't build myself so I can rule that out as a source of the problem) and (s)mplayer which is also kept up-to-date by myself.
moviemaniac
#4 Post by moviemaniac » Sun Jun 20, 2010 9:15 am
Found a copy of 1.5.4's sources on my backintime-backup drive and everything works again, so I'd say this is a regression introduced between 1.5.5 and 1.5.6 (I remember 1.5.5 as working)
moviemaniac
#5 Post by moviemaniac » Sun Jun 20, 2010 11:37 am
Okay, scratch that, 1.5.4 isn't working properly either, it has something to do with streaming from the disk
moviemaniac
#6 Post by moviemaniac » Sun Jun 20, 2010 4:49 pm
Okay, I found the culprit. I switched to the 2.6.35-rc-series about the time when I installed MakeMKV 1.5.6 - reverting to kernel 2.6.34 fixes the problem for me.
crowfax
#7 Post by crowfax » Sun Jun 20, 2010 5:04 pm
Hey,
Sorry I didn't get back to you, real life got in the way! Anyway, glad you have it fixed.
moviemaniac
#8 Post by moviemaniac » Sun Jun 20, 2010 5:06 pm
crowfax wrote:Hey,
No problems. Anyway the real trouble begins now hunting down the real bug (regression) in the kernel - I've never done a git bisect on a project as big as the kernel itself :shock:
