M4V to MKV?
ariesjones
M4V to MKV?
Post by ariesjones »
Two days ago, I tried to convert M4V to MKV with Handbrake, but I failed. Anyone know what happened? Or any suggestions?
Re: M4V to MKV?
Handbrake support is found at https://forum.handbrake.fr , and you will need your encode logs to get help. Their posting template has links to where you can find your logs.
That said, going from MP4 to MKV, you could do that with mkvmerge from mkvtoolnix (Google knows where they are). Load the file into the mkvmerge GUI, specify an output file name, and click on start. It is very fast, and there is no change in the audio/video quality, since everything is simply changed from MP4 container to MKV.
Meister_Proper
Re: M4V to MKV?
Post by Meister_Proper »
Woodstock wrote: That said, going from MP4 to MKV, you could do that with mkvmerge from mkvtoolnix (Google knows where they are). Load the file into the mkvmerge GUI, specify an output file name, and click on start. It is very fast, and there is no change in the audio/video quality, since everything is simply changed from MP4 container to MKV.
Totally agree with you. Best method imo!
