Deleted SVQ by accident. drive can no longer be found.
tim01835
Post by tim01835 »
I have the latest install of MakeMKV on my Mac Book Air. I accidentally deleted my sqv files from my download folder. What is the easiest way to install these back onto my machine?
preserve
Re: sqv
Post by preserve »
The latest SVQ file is always available here:
http://www.makemkv.com/svq/dsall.svq
If you are connected to the internet, MakeMKV will always attempt to download the latest version when it needs it.
Using: ASUS BW-16D1HT 3.00
tim01835
Re: sqv
Post by tim01835 »
preserve wrote:The latest SVQ file is always available here:
/svq/dsall.svq
Thanks for the quick response. I've downloaded dsall, but how do I install it?
After I deleted the files, my discs are no longer recognized by my laptop. I assume it's the lack of SVQ.
Re: Deleted SVQ by accident. drive can no longer be found.
If you've set up your MakeMKV data directory (Preferences->General), MakeMKV will download what it needs into that directory, as it needs them. Otherwise, you "install" them by copying them to that directory.
